d james
| Author | Subject: Re-angled manifold 205 gti6 conversion |
daipugralio
Newbie Location: carmarthen Registered: 18 Oct 2012 Posts: 31 Status: Offline |
Looking for the above, where can I find them and how much?________________________________________ d james |
rikky
i was gonna buy one but after seeing how easy it is to do from doing mine at weekend, i'm glad i didn't DIY FTW ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
How much did you cut out to get the right angle ? And where did you cut it out ? |
JWP EFi
sure i heard somewhere that its a 30 degree cut and reduce length by 30mm, this could be bulls**t though |
superchargedblack1997gti6
bear with me i found this on the 205 forum the other day. ill try an grab the link.________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
I did my own. Used a thin cutting disc to go most the way through then 3 hacksaw blades together to finish. Left about 10mm holding it on and pushed it down 'til if met and had it welded up. Made a suprising difference to the final angle.________________________________________ ![]() |
JWP EFi
so they are not actually shortened then? and btw, thats a clever way of doing it i must say |
Surely Welshpug could comment on this I'm sure he was on the thread I'm trying to link!________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
Not shortened at all.Pics of mine: ![]() ![]() ________________________________________ ![]() |
yep that's how it was shown on the 205 forum too!________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
daipugralio
I'm thinking of heating the end flange (downpipe side) with oxy/acety and teeking it downwards, surely this would get the same result and you wouldn't get a possible build up of weld on the inside pipes by welding large gaps??________________________________________ d james |
naah it wont work down there, as its the pipes that hit the bulkhead seam not the flange.you wont get large gaps as you bend the manifold to close them, and you can always get a die grinder in there to dress the welds down if they are a bit messy ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
daipugralio
Arh right! I presumed the downpipe flange would be the problem and not the pipes, doing the conversion this weekend so will cut the pipes as said..cheers everyone....... ________________________________________ d james |
The flange is the problem - hence cutting the pipes to aim it down a touch!________________________________________ ![]() |
How much material did you remove after cutting ? 3 - 4mm by the looks of things ? |
I just used a thin cutting disc (what, 1.5mm probably? - whatever the thin ones you get are) and then when the grinder bottomed out I continued with the hacksaw blades as mentioned which ended up with the same thickness.You don't want to take too much and have gaps. As Mei says, when you close the gap (it will NOT bend) it should meet well. I was lucky that my thickness of cut was enough to be bang on. I took it to my friendly fabrication place and simply said "Push it until the gap closes and then weld it up there". Ta da: ![]() ________________________________________ ![]() |
I use 1mm discs at work but you can get different thickness blades ? 3 hacksaw blades must be a good 2mm if not 3mm ? |
beez_neez_gt
That's better welding than the one I got from Miles, looks better than the manifolds welds, I wish id made my own now lol. Although I think iirc I didnt have my own welder back then.________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
rikky
on mine I did what dan did - i used a .5mm slitting disc to trim right the way through 95% of the way, then used a 2mm grinding disc to go half way through it again. angled it up with pressure and welded it shut. in the bulkhead I've now got a 10mm clearance which is just right________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
beez_neez_gt wrote: That's better welding than the one I got from Miles, looks better than the manifolds welds, I wish id made my own now lol. Although I think iirc I didnt have my own welder back then. They did a brilliant job for a good price too. Don't forget it's stainless!________________________________________ ![]() |
yippeekayay
Seasoned Pro Location: wilts Registered: 27 Oct 2008 Posts: 4,144 Status: Offline |
Dan can you do another one smartish??________________________________________ 306 less for first time in nearly 7 years. Lets keep it that way... please refuse any offers i make to buy your 306 ( doctors letter supplied by request)Marmite and cheese sandwiches anyone??? Burns and Mcrae will be forever missed. x box "yippeekayaymofo" |
daipugralio wrote: Looking for the above, where can I find them and how much? What are you up to again? |
beez_neez_gt
dangti6 wrote: beez_neez_gt wrote: That's better welding than the one I got from Miles, looks better than the manifolds welds, I wish id made my own now lol. Although I think iirc I didnt have my own welder back then. They did a brilliant job for a good price too. Don't forget it's stainless!s**t yeah I always keep forgettjng that lol, its only T 304 stainless which is why it discolours making you think its mild steel lol. I would.only need the correct type of wire to weld it, is ss harder to weld than mild ? ________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Technique is pretty much identical, it's the shielding gas that varies. Most just use the 5% argon/co2 mix though. Other better gasses are available but for the amount your gonna use its not worth investing in a bottle.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
beez_neez_gt
What the best gas to use then for an easier job, i have a local place that does them cheap with no bottle rentle?________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
