Author Subject: How to remove rear drums ?
Pug bazza
Hello lads, I would like to know how to remove the rear brake drums on my peugeot 306 1.4 meridian on "Y" reg, if any if you guys can point me a right direction, I done this released hand brake and loosened bolt in middle, tried pulling but seems stuck so put it back, so any idea how I could get them off, the bolt on one Hub is hard to open, but the one I opened was hard to get drum off seems hard, any help much appriciated thanks
Posted 3rd Jul 2013 at 20:45
gilesy
Rear drums?
Try 306oc
jord294
Back off the adjuster through the wheel bolt hole
Posted 3rd Jul 2013 at 20:50
Pug bazza
Lol the truth is you guys, know more than the other peugeot rooms,you lot are wiser and always point me in the tight direction that why I put my drum request on here, lol pretty please with a gti-6/rallye on top
Posted 3rd Jul 2013 at 20:51
Pug bazza
Thanks Jord, il do that hope that makes it easier to get of pain in arse this puggy pug pug is lol
Posted 3rd Jul 2013 at 20:53
They are tight to remove due to the lip that will be present on the inner edge of the drumWink the shoes do not make contact with the drum right to the outside.
Remove the lip with a flap disc in a drill once the drums are offThumbs up
Posted 3rd Jul 2013 at 20:58
Pug bazza
Thanks coskev, so would I have to try leavering it out somehow, after loosing the adjusting bolt
Posted 3rd Jul 2013 at 21:01
No,if the adjuster is wound off they should just slide offYes
Never worked on a 306 with rear drums,but if Andy says you can get to them threw the back plate you will be fineThumbs up
Posted 3rd Jul 2013 at 21:05
slacken the handbrake cables off too Thumbs up
Pug bazza
Thanks welshpug, appriciate all your help guys
Posted 3rd Jul 2013 at 21:07
Good shoutThumbs up
As numpties use the handbrake cables to adjust the rear brakes sometimesThumbs down
Posted 3rd Jul 2013 at 21:17
Pug bazza
Sorted guys, will do that thanks guys appriciate it,
Posted 3rd Jul 2013 at 21:22
