Author Subject: camshafts
mike rallye
Hi guys I have just brought some up rated camshafts for the six, and what I need help with is
Am more than happy to change the timing belt and kit , but I have not changed camshafts before and what I want to know is , could there be a chance the camshaft could spin when I slacken the. Timing camshaft pulley bolt?
Cheers mike
Posted 5th Jul 2013 at 22:55
miles
What are the cam's? I take it you have seen what happens if you don't do a dry build with anything with any decent lift
www.pugracing.com
Posted 6th Jul 2013 at 22:23
I have them and they are only piper 270 so only mild nothing silly lift No
The cams will move slightly when you take the timing pins out Yes
Posted 6th Jul 2013 at 22:31
The cams can 'spring' forwards/backwards when you remove the timing pins as when you pin them up they are on 'rock'. Yes
Posted 6th Jul 2013 at 22:53
Project D
I installed Newman PH2 cams and idle is now really rough. Should it be like that?
Here's video. http://www.youtube.com/watch?v=uWo9pquCpZs
Posted 9th Jul 2013 at 14:55
Have you had it re-mapped?
Posted 9th Jul 2013 at 15:16
Project D
No.
Posted 9th Jul 2013 at 16:17
have you timed them up properly ? mine idles same as standard with these cams and unmapped.
Posted 9th Jul 2013 at 16:42
Project D
I timed them on standard marks/timing.
Posted 9th Jul 2013 at 16:55
get it done properly.
Posted 9th Jul 2013 at 18:14
mike rallye
Will the valves not move when the tension comes off the camshafts? And which one do I re time fist inlet or exhaust ?
Posted 10th Jul 2013 at 13:37
When the tension is taken off the camshaft, i.e. you remove them the valves will shut.
Personally, I would time the exhaust one first, but that's simply because it's he more difficult one to get to as it's at the back. Thumbs up
Posted 10th Jul 2013 at 19:34
mike rallye
As there not much real intrest in my cams , am going to fit these within the next month. Is there a chance I could bend the valves when re timing it?
Posted 27th Jul 2013 at 22:45
Hi bud
If your not confident doing the cams your self bud ill get it done for you ? I have a top mechanic who has done this job many times ? Get it wrong and kiss good by to the valves ?
Contact me if you need help bud
Posted 27th Jul 2013 at 22:53
mike rallye
What sort of price would I be looking at ?
Posted 27th Jul 2013 at 22:55
Yes
If you're not sure what you're doing as Chris says then it's best to pay somebody to do it for you. Thumbs up
Posted 28th Jul 2013 at 01:07
