Author Subject: elec windows wont come up!
Takedown
Aaaaaaaaaaaaaa it must be that the car is French...
Windows went down perfectly, now i want them up and nothing happens on both sides, only a little click sound inside the door...
Im getting fed up with these little s**t error/faults
Is there a way to "reset" the windows or something? or does anyone have an idea
Its with both windows...
thankyou
Posted 8th Jul 2013 at 15:08
Matt_rallye
Sounds like a relay it something.
Posted 8th Jul 2013 at 16:58
If you hear a click inside the door, at least it proves the signal is getting from the switch to the motor mechanism, which is probably knackered. Time to pull the door apart and have a look. Yes
Posted 8th Jul 2013 at 18:14
scotzman
I doubt both motors packed in at the same time
Posted 8th Jul 2013 at 18:25
Doh
I didn't read it was BOTH sides...sounds like a door loom problem then on the driver's side. Yes
Posted 8th Jul 2013 at 19:01
Niall
Yep broken wire on the drivers door loom. Get someone to hold the switches up then wiggle the loom wires. If it starts to go, have fun repairing wires Big grin
Posted 8th Jul 2013 at 22:25
Yeah, you can either repair the wires or buy a replacement door loom although I believe they are quite pricey. Yes
Posted 9th Jul 2013 at 08:16
Niall
£80 but at least then you know it's done and won't break again. It's also a revised design I believe.
Posted 9th Jul 2013 at 09:27
cully
replacement loom from peugeot
Peugeot part no 6542 VQ Price £97+VAT
Posted 9th Jul 2013 at 11:37
this happened to my mates, turned out to be a fuse
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 9th Jul 2013 at 13:17
Takedown
Its not the fuse.... now the driversside doesnt even click anymore...
Thumbs down Angry
Posted 9th Jul 2013 at 22:56
Not the fuse but a fuse, think it was rear wiper motor fuse Hmm
Posted 9th Jul 2013 at 23:30
anth
Sounds like the loom, especially if both have died at the same time. Easy job anyway.
Posted 10th Jul 2013 at 06:52
Takedown
Uhmm
Maybe im being stupid, but then on the passengersside when i would use the buttons it should work right? cause also on the passengersside the button does nothing.
When on the driversside, where also the passengersside button is, they also both dont respond anymore, where the driversside use to "click" inside the door, it also has stopped doing that.
Getting tired of these weird electrical problems and then i havent even driven the damn pos yet :S
Posted 10th Jul 2013 at 23:03
sixysix
I would say drivers side switch or drivers side loom broken.
IIRC, if you disconnect the drivers switch, the passenger side switch will not operate off it's own buttons.
That's how my Phase 1 window switches work anyway Smile
Take a look
Posted 11th Jul 2013 at 13:46
Takedown
oke thx mate...
Posted 12th Jul 2013 at 11:16
If you find a broken wire (very common) then add in another 5cm or it will only go and snap again.
Posted 12th Jul 2013 at 13:51
This. Yes
The driver's side is the "master" and if that's not working, the passenger side (being slave) doesn't get any power. Smile
Posted 12th Jul 2013 at 15:02
marco gti6
Haha Paul... what did i just tell you this morning LOL
Isn't it great to get inside the car after it has stood all day in the sun to find you cant even open the damn window?
Need to do mine too... if you go to your pug dealer let me know the price, maybe they are cheper in NL than in LUX or you can get a discount for buying 2 Razz
Edit Your's a ph1 right? In that case its a different connector if IRC?
Posted 12th Jul 2013 at 15:38
Takedown
ph1 different connector, bought a fresh one from someone for 25 euros Wink
just have to see if it works....
Posted 15th Jul 2013 at 16:51
jimmyhackers
i saw this thread before mine went and now ive fixed it i thought id see if you have a similar problem. i thought fuse and loom and relay etc etc....
tried the same as you fuse relay. then i checked the loom, google search a picture of a (306 broken door loom) the wire should be pretty visable with a break in it. just slide the corrrigated rubber up to expose the wires to check your own.
i didnt find one in mine. then i saw the pins in the plug were corroded, a few mins of fiddly labour with a little bit of emery paper and it was fixed.
if you cant see a break in a wire try cleaning your pins before replacing the loom
hope this helps
Posted 3rd Aug 2013 at 01:25
