| Author | Subject: Fuel light/guage question |
DanRM
Regular Location: Birmingham Registered: 18 Jan 2013 Posts: 120 Status: Offline |
Just a quick question now that my 6 is finally on the road, When I bought the car the lad said that the gauge goes down to 1/4 and stops there. I'm not too fussed about that, but is the fuel light on a different sender? So instead of playing it safe and filling up every 3/4 of a tank I can just drive till the light comes on? I better keep a jerry can in the boot just in case. |
Niall
Seasoned Pro Location: Epsom Registered: 06 Jun 2012 Posts: 1,941 Status: Offline |
Thats bo***cks. The gauge will go down all the way unless yours is fooked. The light will come on at the top of the red and i would say you have about 30 miles left after that. |
dan_s16
Seasoned Pro Location: Cheltenham Registered: 22 Jan 2005 Posts: 1,583 Status: Offline |
The low fuel light and the gauge work from the same sender. when the sender reaches a certain fuel level and outputs a specific voltage to the instrument cluster it turns the light on. if the low fuel light comes on you know its the gauge playing up, if you run out of fuel before the light come on you know some things not right with the sender, its either getting stuck or just faulty.________________________________________ When I've got time I forget what I wanted to do, and when I remember what I wanted to do, I have no time! |
gnrlee
Forum AdminLocation: Leeds Registered: 20 Aug 2005 Posts: 8,891 Status: Offline |
has someone had the Cluster pannel apart at some time and not put the needle back in it's proper place?i take a picture when i mess about with the needles to make sure they go back in the right place! here's how they should sit while off,.. ![]() try resetting yours to this pic and see what happens! there will be a tutorial on how to get into the cluster about somewhere if you're not sure! ________________________________________ Proud Member of the ASTOR Owners Club |
DanRM
I'd say it's a fault with the sender then as the light doesn't come on during ignition, (assuming it should) I managed to get 396 miles before chickening out and filling up again and put 54 litres back in so I'd say I would have been near the point where the light should come on |
stan_306gti6
Yes, it sound like the sender is at fault, as the light should illuminate when you first turn the ignition on. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Have a look at what position your sender is set at in tank Remove the big round rubber grommet from under drivers side rear seat, you will see the top of sender/pump assembly.if the petrol pipes are pointing straight forward undo the big locking ring and turn the sender unit so they point at circa 25 too the hour Had this on mine after refitting the sender, the float catches the tank before it gets to its lowest point ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
stan_306gti6 wrote: Yes, it sound like the sender is at fault, as the light should illuminate when you first turn the ignition on. ![]() Mine doesn't, only comes on when the actual fuel level is low enough to put light on ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
stan_306gti6
coskev wrote: stan_306gti6 wrote: Yes, it sound like the sender is at fault, as the light should illuminate when you first turn the ignition on. ![]() Mine doesn't, only comes on when the actual fuel level is low enough to put light on You've got me wondering now. ![]() It's so seldom I drive the car I honestly can't remember although I always thought it did. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Niall
coskev wrote: Have a look at what position your sender is set at in tank Remove the big round rubber grommet from under drivers side rear seat, you will see the top of sender/pump assembly.if the petrol pipes are pointing straight forward undo the big locking ring and turn the sender unit so they point at circa 25 too the hour Had this on mine after refitting the sender, the float catches the tank before it gets to its lowest point Also, there is a little arrow on top of the pump/sender that lines up with another arrow/mark on the tank so you know it's in the right place. |
demondriverdan
Fairly certain the light doesn't turn on when you turn the ignition on unless the car is low enough on fuel for it to be on. Changing the pump / sender isn't a massive job, didn't take too long when I did it.________________________________________ Rallye Race Car |
DanRM
Ok thanks chaps, I'll have a look over the weekend, the float may just need freeing up or something |
gnrlee
demondriverdan wrote: Fairly certain the light doesn't turn on when you turn the ignition on unless the car is low enough on fuel for it to be on. Changing the pump / sender isn't a massive job, didn't take too long when I did it. this! my fuel light only comes on when i'm low,.. but not on 1st turn or ignition if there's plenty in! ________________________________________ Proud Member of the ASTOR Owners Club |
stan never has any fuel in his car as it all evaporates away due to his heated garage.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stan_306gti6
welshpug! wrote: stan never has any fuel in his car as it all evaporates away due to his heated garage. ![]() I think I've got between a quarter and empty at the moment. Shockingly, the car hasn't even been touched since Pugfest yet. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Did you clay bar the undercarriage fully when you got home and put it away Stan? ![]() ________________________________________ ![]() |
rallyestyle
Seasoned Pro Location: London Registered: 23 Jul 2003 Posts: 14,991 Status: Offline |
Little bit of a thread revival...My fuel dial is stuck (i may have played around with it in the past ) so that it doesn't show the current level. Just to clarify, even with the guage stuck the low fuel light should still come on independently? They work off of the same sender but one is part mechanical if you like?Correctomondo? ________________________________________ Just Drive It |
gnrlee
Yeah the low light will still come on,..If you want to reset the pointer use the pic above my light comes on as soon as the needle hits the red And make sure you don't press it all the way down Or it will stick,.. If you turn the gage it should move freely back to It's original position ![]() ________________________________________ Proud Member of the ASTOR Owners Club |
rallyestyle
gnrlee wrote: Yeah the low light will still come on,.. If you want to reset the pointer use the pic above my light comes on as soon as the needle hits the red And make sure you don't press it all the way down Or it will stick,.. If you turn the gage it should move freely back to It's original position ![]() Cheers bud I pushed it down too much previously and haven't the time to get the dils out again and reset it, just need to make sure i know when im running out of fuel ![]() ________________________________________ Just Drive It |
