Author Subject: Omex Ecu
pete_rallye
Omex 500 series ECU, full ignition+fuel control. Quite an old ECU now but works fine and plenty of support for it still on Omex's website. Comes with loom to suit 4 cylinder engine. Works perfectly! Currently mapped for a gti6 engine on throttle bodies with 11mm lift cams.
£450ono
Lap of the 'ring
Posted 15th Jul 2013 at 23:11
JWP EFi
Turbo Legend!
out of curiousity does this need an interface and if so is it easy to to obtain?
Posted 15th Jul 2013 at 23:22
pete_rallye
Yeah, its a serial cable, £5 from Maplin or 99p from ebay. Unless you're using an old laptop you'll also need a serial>usb adaptor, £10 from Maplin, or 99p from ebay.
Lap of the 'ring
Posted 15th Jul 2013 at 23:24
does it run a crank pulley side 36-1 wheel or the stock pug flywheel?
Posted 15th Jul 2013 at 23:26
pete_rallye
standard flywheel.
Lap of the 'ring
Posted 15th Jul 2013 at 23:27
