15"
| Author | Subject: Would these fit? |
drewhughes
Regular Location: Coalville Registered: 20 Jun 2013 Posts: 130 Status: Offline |
4 stud 7jx15-ch15" |
depends on offset and pcd.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
What PCD and offset?________________________________________ ![]() |
drewhughes
http://www.ebay.co.uk/itm/TEAM-dynamics-pro-race-1-2-15-set-of-4-/121142903805?pt=UK_CarParts_Acc_Wheels_tyres_Trims_Car_Rims_ET&hash=item1c34ae03fd this is all i got. they came off a clio |
renfault = nonothey are 4x100. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
drewhughes
so whats the full size I need then for a straight fit on the 306 if im running r888'sET, Offset, PCD etc Just so I dont have to keep posting on here every time some come up on ebay haha |
burnout21
Regular Location: Edge of the Pass Registered: 23 Apr 2008 Posts: 248 Status: Offline |
4 x 108 is what you need. You can use spacers for different offsets etc. Think most Ford's fit. But someone will correct me if need be. |
For reference, the ET** stamp is the offset.________________________________________ ![]() |
ET15 is ideal for a 7 inch wide rim________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
birk
Seasoned Pro Location: Doncaster Registered: 24 Oct 2005 Posts: 7,032 Status: Offline |
195/50/15 tyre, r888 are pretty chunky.________________________________________ Dimma + Gt35 turbo =![]() Solid rear beam mounts £130 07889376885 Dan |
drewhughes
how bout these?Ford fitment 4x108 pcd. Offset is i believe ET35/38 |
no, pug needs ET 19 on a 6" rim, 15 or less for 7".________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mik
Seasoned Pro Location: Kent Registered: 17 Feb 2011 Posts: 2,100 Status: Offline |
Also need to look at centre bore and get a spigot ring to fit if necessary as it is essential for safety reasons that the wheel centre bore fits correctly on the hub. The bolts only do part of the work. IIRC Ford fitment wheels do not have the same centre bore size as Peugeot - someone else on here will know the exact sizes. ________________________________________ Cherry Rallye SOLD |
they're smaller, so a spigot would be a fat lot of good ![]() you'd need ford to pug spacers, which weigh a ton and cost a lot. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mik
...or get them reamed out to appropriate bore by someone who knows what they are doing if other dimensions were right? ________________________________________ Cherry Rallye SOLD |
