displaying posts 1 to 1 of 1
Author Subject: Maniflow manifold and pugsport exhaust
pete_rallye
I bought this manifold direct from Maniflow a few years back. It has since had a motorsport cat welded to it, although this could be removed and a bit of pipe welded on if wanted. Has a lambda sensor point too.
Also available is a pugsport exhaust which has for some unknown reason had the normal tailpipe chopped off and a mild steel bit of tube welded on. Looks a bit gash really but does the job. Center section is in good nick and is designed to fit the above manifold.
Looking for £350ono for the manifold with cat , exhaust is FOC. The exhaust is designed to fit the manifold, and well, its not really worth anything as it is so if the manifold buyer doesn't want it, it'll go for scrap unless you register you're interest in it...
Lap of the 'ring
Posted 21st Jul 2013 at 22:06
