Author Subject: brembos
Are 406 coupe brembos the same as v6 xantia ones?Dunno
If they are do you still get the brake squeal probs if you use xantia discs and calipers?
Posted 29th Jul 2013 at 16:56
xantia never used a brembo caliper.
Posted 29th Jul 2013 at 17:01
Ah right, so it will be 406 v6 brembos and xantia discs then.
Reading up it seems even on the 406 they were fitted too oe they have noise probs?Thumbs down
Posted 29th Jul 2013 at 17:40
indeed the Xantia or C5 288x28 disc is the one used when converting a pug
the xantia had the classic handbrake on the front system with a girling caliper, brembo afaik don't do any handbrake calipers.
406's some do squeal some don't, but invariably when they're fitted to a 205/306 hub which has a taller bell and a lower lug radius then they squeal lovely.
Posted 29th Jul 2013 at 17:48
Never had to much noise with mine on stnd pads !
Had some noise with Race pads !.....Race pads which you don't need on the road...simple Thumbs up
A couple of thin silicon lines on the back of the pads seemed to sort 90%
Posted 29th Jul 2013 at 17:52
