Author Subject: mot pass : ) elec window fail :(
jimmyhackers
i passed my mot (third time lucky)
anyways, garage man left driver window open. i wound it up and drove home, 4 mins into the journey i decided i want my windows open. both have stopped working. i mite of pressed up before i pressed down but i dont think itd be a burnt motor as both have stopped working
its not a fuse ive checked every single one :s, ive swapped over all my relays so i dont think its that (not sure which does elec windows and the relays i swapped over were from a crashed gti). i dont hear any clicking when i press the button.
can someone point out exactly where to look for this ellusive snapped wire in the drivers door loom with a pic or a good description. is it a wire in the door hing space just above that multiplug, or am i looking in my drivers door?, or am i looking under my dash?
help or pic greatly appreciated as always
jim
Posted 31st Jul 2013 at 20:27
scotzman
Door loom in the rubber grommet thing at the hinge.
Posted 31st Jul 2013 at 20:29
jimmyhackers
dont spose you know what colour wire to look for aswell?
Posted 31st Jul 2013 at 20:32
scotzman
On mine it was a heavier white wire and was broken right at the plug so was difficult to mend.
Posted 31st Jul 2013 at 20:34
tvrfan007
Does the pass window work from its own switch?
If your rear wiper isn't working it could well be the fuse.. check it for continuity not just visually - i chased my tail for a week for such an occurence.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 31st Jul 2013 at 20:37
scotzman
If the wire to the drivers switch is broken I don't think the passenger switch works either.
Posted 31st Jul 2013 at 20:41
Correct, once the driver's door loom is broken it cuts the power going to the passenger door as the two seem to run in series. Yes
Posted 31st Jul 2013 at 22:34
jimmyhackers
ill have a gander at it tommorrow. just out of interest if i cant fix it with a soldering iron. how intensive of a job is the wiring loom replacement?
do i need the dash out or.. the instrument panel.. etc etc
does it plug in or will i need to cut and solder it in places?
how far/deep will the new loom wires go from the point of entry to the car?
thanks again
jim
p.s. if i dont find a broken wire could it just be the switch thats gone??
Posted 1st Aug 2013 at 00:51
There will be a broken wire. Yes
As for changing the loom, I've never actually done it but from others say about it, it's a fairly simple job with no dash removal etc. Smile
Posted 1st Aug 2013 at 09:01
mik
Posted 1st Aug 2013 at 09:54
jimmyhackers
thanks for the info,
sorted it myself this morning, wasnt a broken wire! thank god
was just the pins in the door loom plug beign all greeny corroded, 10 mins with a bit of grit paper and it was sorted.
Posted 1st Aug 2013 at 13:44
I did the same
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 8th Aug 2013 at 13:32
