cheers
Bianca 306 Rallye.Mondeo Titanium X.
| Author | Subject: TICKING ENGINE. |
Nose
Senior User Location: Birmingham Registered: 23 Jun 2013 Posts: 994 Status: Offline |
Hi guys, what actually is it that causes this problem, valves, lifters, rocker arms ? I see it mentioned from time to time , but curious as to what causes it.cheers ________________________________________ Bianca 306 Rallye.Mondeo Titanium X. |
stan_306gti6
Moved to Engines. ![]() The reason has been listed before many a time. Essentially, there are valves which are ever so slightly bent and therefore the spring strength of the valve spring is strong enough to pull the valve back onto it's seat and create a seal thus the lack of compression loss. However, this constant 'bending' of the valve eventually weakens it and the head snaps off resulting in severe engine damage or complete failure. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
stan_306gti6
Does your engine suffer from this then? ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Tap or tick? ![]() ________________________________________ ![]() |
stan_306gti6
dangti6 wrote: Tap or tick? ![]() Good point, tapping will be the bent valves as indicated above. Ticking will be loud injectors, not really much can be done about that. I always found the 440cc low boost injectors to be the loudest. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
no rockers, lol.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Takedown
Senior User Location: Holland Registered: 18 Oct 2012 Posts: 845 Status: Offline |
Even from looking at RFS valves they bend... |
Roon
Junior User Location: Chichester Registered: 06 Jan 2013 Posts: 91 Status: Offline |
Mine ticks like a cow! Noisy ass injectors! |
stan_306gti6
As I say, it depends on the injector but I've found both the standard injectors and the Bosch 440s are quite loud. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
