displaying posts 1 to 25 of 30
Author Subject: Re-built KAD 6-pot's *SOLD*
As above only been rebuilt a few weeksWink
Awesome brakes compared to standardCool
These calipers fit straight onto the Gti6 hub and us a standard sized disc.
Pics below of the clearance under my Pro-Race 1.2's,I have not got any Cyclones to check if they will deffo fit under them nowRoll eyes I think you would need some spacers and disks to get them under Cyclones after looking at other threads on here and speaking to Ross about his:
http://www.306gti6.com/forum/showthread.php?id=156571
In Chris's thread you can see some spacers on the brackets,pretty sure these are required to fit these under Cyclones without running wheel spacers:
http://www.306gti6.com/forum/showthread.php?id=131360
New set of Mintex M1144 pads just bedded in.
New seal kit,pad retaining springs and decals from KAD,
calipers and brackets powder coated,
new link pipes,
new ht bolts,
all threads cleaned up before building,
stainless bleed nipples.
These will be available in a couple of weeks.
Looking for £350 deliveredThumbs up
Posted 15th Aug 2013 at 17:08
what's the weight of them kev? is it a standard pad shape?
Posted 9th Aug 2013 at 19:09
Would have to weigh them once removed to be exact,but are lightThumbs up
Presume pads are readily avail,they came with the calipers so didn't order them myself.
Pads look like these:
http://www.kentautodevelopments.com/shop/product/kad-mini-brake-pads-6-pots-road-mintex-m1144
Caliper is type F if anyone wants any info off KADWink
Posted 9th Aug 2013 at 19:57
You don't happen to have a C5 'steel' knocking about do you Kev?
  • Posted 9th Aug 2013 at 20:28
    I haven't soz danNo
    Posted 9th Aug 2013 at 21:24
    rallyeash
    My Kad 6 pots that turned up today are going under C5's well hopefully!
    309 3dr K20 Type R
    Posted 9th Aug 2013 at 23:40
    Verrrrry interesting....
    Posted 10th Aug 2013 at 08:14
    BumpThumbs up
    Open to offersWink
    Posted 12th Aug 2013 at 09:38
    soton_s16
    Can anyone confirm if they fit under C5 wheels?
    For all your Peugeot needs PugRacing.com
    Gti S16 199bhp 164 ft lbs torques!
    Posted 12th Aug 2013 at 20:09
    rallyeash
    just been trying them this evening. Ive had to do whats in the second link and use the spacers to bring the caliper back towards the inside of the wheel arch. the calipers foul on the C5 rims on "spoke clearance" literally by about 2mm.
    i dont know what discs they are though as mine came with my 6 pots but the offset is miles different to the GTi6 ones i removed.
    Im going to get some hubcentrics though as i dont want 3mm spacers on my track car so going to run 10mm hub centrics i think.
    309 3dr K20 Type R
    Posted 12th Aug 2013 at 20:27
    Pretty sure Ross said KAD supply those discs.Thumbs up
    Posted 12th Aug 2013 at 20:30
    rallyeash
    i thought that might be the case, ive just text him actually to try and confirm, i also thought might of been of a different model Pug or somethin giving a different disc offset.
    309 3dr K20 Type R
    Posted 12th Aug 2013 at 20:37
    MK1 focus RS iirc.
    Posted 12th Aug 2013 at 21:26
    MK1 focus RS iirc.
    Think they can be used, but need the centres machining.
    KAD supply a direct fit diskThumbs up
    Posted 12th Aug 2013 at 22:16
    superchargedblack1997gti6
    Kad direct fit with offset to bring caliper further inboard
    Posted 13th Aug 2013 at 11:42
    soton_s16
    So using these discs, does that mean these will 100% fit under C5 wheels with no need for spacers? Unsure
    If so, I am very interested.
    Posted 13th Aug 2013 at 13:30
    matty_rallye
    No. Ash had the spacers to bring the calipers in and they still hit the wheel, just.
    2.1 16v 306 Rallye.
    Posted 13th Aug 2013 at 13:55
    Ive never tried to use c5s and they must sit slightly more dished in than other 15 inch wheels IMHO.
    Posted 13th Aug 2013 at 13:58
    Got someone pretty sure they are having these, pending wheel clearance.
    Anyone know for sure that 15 inch pro-race 1.2's will clear these?Thumbs up
    I'm pretty sure thry will looking at the spare space under my 16'sYes
    Posted 13th Aug 2013 at 17:39
    rallyeash
    Well I've now managed to fit mine under 15' C5's with NO spacers and 1.2's have much more spoke clearance.
    309 3dr K20 Type R
    Posted 13th Aug 2013 at 19:09
    Glad you got em sorted Ash
    Posted 13th Aug 2013 at 19:12
    With no wheel spacers?Or no spacers between hub and caliper bracket?Dunno
    Posted 13th Aug 2013 at 20:49
    I'm pretty sure youres will fit under 15 inch team dynamics Coskev. I'm happy to send you a wheel if you would like to check?
    Posted 13th Aug 2013 at 21:03
    That's a great offer cheers RossThumbs up but I think buyer is taking the risk looking at the clearance on my 16'sWink
    Posted 13th Aug 2013 at 22:52
    Dammit!
    Tell him they dont fit and sell them to me Laugh
    Posted 13th Aug 2013 at 22:57
