displaying posts 26 to 50 of 51
Pages (3): 1 [2] 3
Author Subject: Coolant pressurising
blandy
They did supply a cap with it but will check that rating tomorrow. As 1.4bar would be around 21psi so will check that to be sure. Can't see it being a issue with the rad itself as can't see much to go wrong with a rad not that could cause pressure.
Its definitely gaining pressure as its pushing the coolant out and then I bleed it again which then takes the collected coolant to top it up to around mid way on the tank.
Posted 10th Aug 2013 at 19:55
blandy
Just looked at pro alloy caps which is what was supplied and it states 21psi so prob is right but will double check it tomorrow as well as having a good look at the cap etc
Oh and takedown yeah ill send you a beer if your right dunno how it'll hold in the envelope though lol
Posted 10th Aug 2013 at 20:01
All coolant systems are pressurised, hence the cap being rated to a certain level before it releases excessThumbs up
If your cap is weak it could be releasing before it should, if your car is producing excess pressure you will feel it by squeezing top hose, will be virtually solid and you won't be able to squeeze itSmile
Posted 10th Aug 2013 at 22:51
blandy
Well done a second sniffer test today and the results were not good as it turned colour strait away so kinda confirms it all now Sad which is but annoying as engines only been in a matter of months as a good engine and done around 600miles and have had a lot of cooling issues for a lot of that's although have never even got close to overheating as I've always been paranoid about it so watched it so carefully so can only imagine its had the underlying issue for some time..
Also whipped the head off and there's no life left in the head
Posted 11th Aug 2013 at 18:47
Do you mean the head has no more meat left to skim off? Dunno
Posted 11th Aug 2013 at 18:56
blandy
Yeah it's basically flush can't even feel a step so beyond another skim
Posted 11th Aug 2013 at 18:57
Oh dear, replacement head time then. Sad
Posted 11th Aug 2013 at 19:24
Measure the height of the head, given that is an o.e pug gasket its not likely to have been off before.
Posted 11th Aug 2013 at 19:38
I can see the step there, so surely you can feel it?!
Posted 11th Aug 2013 at 19:40
Post #35
Yes, having actually now looked at the photographs, I also can see the step now. Yes
Surely there must still be some life left in that.
Posted 11th Aug 2013 at 19:45
blandy
Post #36
No it's litterally dead flat can barely feel it with fingernail, the pic is pretty poor and yes it has 100% been off before as I was told the gasket was done around a year before I got it plus look at the valves some are different
Posted 11th Aug 2013 at 19:53
rallyeash
Post #37
It is possible to buy a repair gasket from pug that is thicker.
It is for a XU7 though but I ran one on my old engine
309 3dr K20 Type R
Posted 11th Aug 2013 at 20:03
Post #38
you wont want to use an XU7 gasket, as that'll be 83mm bore.
but you can indeed buy an XU10 repair gasket, its listed for the J4R engine.
measure it before you throw it away.
gasket looks a hell of a lot older than a year or so...
Posted 11th Aug 2013 at 20:08
blandy
Post #39
Yeah will measure it just to be sure before doing anything with it.
Posted 11th Aug 2013 at 20:13
rallyeash
Post #40
Yeah sorry that was on my old mi bottom end with a XU10 head
309 3dr K20 Type R
Posted 11th Aug 2013 at 20:16
Post #41
Yes, I believe the repair gasket is 1.4mm thick as opposed to 1.2mm. Welshpug will be able to confirm though. Smile
Posted 11th Aug 2013 at 21:11
Post #42
yup, spot on, to go with the pug specified 0.2mm skim limit.
Posted 11th Aug 2013 at 21:16
JWP EFi
Turbo Legend!
Post #43
according to my local Peugeot dealers, 2 of them, the 1.4mm gasket is not available however gaskets are easily obtainable from various factors, 1.3/1.4/1.45mm but listings are for the S16 and 8V turbo. Same gasket but won't be a Multi layer steel. i Recently had a head skimmed that was already damn close to being flush with the marker, fitted a 1.45 gasket. Personally i'm not a fan of fibre head gaskets so the only way round this is to either pocket the pistons or source another good head
Posted 11th Aug 2013 at 21:25
Post #44
405 T16 used fibre with 1.2 bar, I would have no issues using one, they are not known to give issues.
quite odd all these engines are getting to 15 years and the gaskets giving up isn't it.
Posted 11th Aug 2013 at 21:28
Post #45
just thought of something else to check, have a look across the top of the water jacket on the block, not very common, but have been known to crack across the top of them.
Posted 11th Aug 2013 at 21:29
JWP EFi
Turbo Legend!
Post #46
Mei you are bang on! mine has 2 cracks exactly where you just mentioned, i will post a pic tomorrow. i suspected a cracked head, had it pressure tested a second time and got the all clear. after a standing and staring at the block i noticed something
Posted 11th Aug 2013 at 21:34
Post #47
Re-used the old gasket by looks of it!!!LOL
Posted 12th Aug 2013 at 06:14
Post #48
At least you've found the issue now rather than when you rebuilt it.
Posted 12th Aug 2013 at 07:32
Post #49
Said it wasnt the head Wink
Posted 12th Aug 2013 at 07:47
JWP EFi
Turbo Legend!
Post #50
well done you!
this is the first cracked gti6 block ive ever seen, i have had the occasional cracked head. i would have expected the alloy to crack before cast iron. Everyday's a school day lol
Posted 12th Aug 2013 at 21:02
Pages (3): 1 [2] 3
