Author Subject: GTi6 pas pipes
marksorrento205
Right I am after the following - all from a GTi6:
A high pressure steering pipe (that goes from the pump to the rack)
The pas fluid tank
The pipe that goes from the tank to the pump
The low pressure return pipe (that goes from the rack to the fluid cooling pipe on the front cross member - don't need the cooling pipe though)
Also the small valve that sits in the servo pipes near the vac pump that has three pipes connecting to it and one port blanked off.
A throttle body - can be blank with no sensors as I only need the throttle cable bracket from it.
What have you got? Cheers Smile
Posted 1st Oct 2013 at 07:32
tvrfan007
I have a tb. £15 delivered. Smile
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 17th Aug 2013 at 14:59
t3ora
I might have all the power steering items but can't check it monday day if u can wait.
Road/track car coming together slowly
Posted 17th Aug 2013 at 20:30
I've a power steering fluid reservoir and the high pressure pipe. An option if you can't find all from one seller.
  • Posted 17th Aug 2013 at 21:20
    got the servo valve thingy Smile
    Posted 18th Aug 2013 at 15:38
    marksorrento205
    Pm's on route Smile
    Posted 18th Aug 2013 at 19:38
    marksorrento205
    Ok still need a
    gti6 pas hp pressure pipe with sensor
    gti6 lp return hose from the rack to the cooling pipe
    gti6 pas tank with hose to the pump
    Let me know what you have please Smile
    Posted 1st Oct 2013 at 07:33
    Niall
    Ive got the tank with hose from the pump. Yours for £12 delivered.
    Posted 1st Oct 2013 at 20:25
    mechanical_repairs
    I have the high pressure pipe.
    £20 delivered.
    Carl
    Posted 2nd Oct 2013 at 19:11
    marksorrento205
    Thanks both for your replies. I am now sorted with a full set up. If for any reason there is an issue I will give you both a shout. I may need another one next month any how for my 205?
    Posted 2nd Oct 2013 at 22:08
