Team Nile 6
Team: 40.2 MPG
5 x a 306 owner!
currently abusing type r's in a town near you ™
I truely live for the 306 ®
midweek madness
displaying posts 1 to 25 of 43
| Author | Subject: Cambelt cover. |
mattgti6phase2
Seasoned Pro Location: inside my 6 abusing the tarmac!! Registered: 16 Jul 2010 Posts: 2,371 Status: Offline |
As above I'm looking for a cambelt cover in good condition please. Mine has burn holes in it from when it was poorly fitted after my cambelt change and the aux belt has worn it away ________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
Seasoned Pro Location: Parts for Sale section Registered: 04 Dec 2007 Posts: 7,442 Status: Offline |
I've got one Matt ![]() I assume I have the correct one to fit your phase 2, the one with the sliding mechanism on? ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
gnrlee
Forum AdminLocation: Leeds Registered: 20 Aug 2005 Posts: 8,891 Status: Offline |
all the same ![]() ________________________________________ Proud Member of the ASTOR Owners Club |
gnrlee wrote: all the same ![]() Really? I thought I heard that some of them have 10mm bolts, and some have a sliding mechanism on? Not sure myself though ![]() ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
gnrlee wrote: all the same ![]() Incorrect. Earlier ones have a sliding mechanism where the others have 2 nuts to the centre. ________________________________________ ![]() |
Well then Matt, need to check which you have. I have the sliding mech type, which is the earlier one according to Dan.________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
Here's the one I have available:![]() ________________________________________ ![]() |
And I bet that is the one he needs! Go away Dan ![]() ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
mattgti6phase2
that's the one i need!!! Although Dan is correct about them being different between the phases they are still interchangeable but the early type ones are s**t! ________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
mattgti6phase2 wrote: but the early type ones are s**t! Thanks for ruining the sale of mine then ![]() ![]() ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
mattgti6phase2
sorry bud didn't realize Ok I'll try and salvage it for you. They work just fine, however the sliding mechanism interferes with the master cylinder resivour. And if Dan didn't have one I'd buy yours ________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
stan_306gti6
dangti6 wrote: gnrlee wrote: all the same ![]() Incorrect. Earlier ones have a sliding mechanism where the others have 2 nuts to the centre. Incorrect, the actual cover is the same. Early types had a bar which fitted in the vertical slot and there were two 'bobbins' which fitted through the holes and the bar slid over these to lock it in place. The later type changed the bobbins for threaded bar and you need to affix it with two M6 nuts. ![]() However the cover design is identical in both parts. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Without splitting hairs - the fitment differs, so it's worth noting as had Matt purchased CJM's on GNRLEE's advice he could have got it and found he needed the mechanism fittings to the engine also which may or may not have been supplied in it's entirety.________________________________________ ![]() |
not identical, late covers will rub on the bolts of the earlier pulleys.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
AWW Welshpug COME ERE!![]() ________________________________________ ![]() |
stan_306gti6
welshpug! wrote: not identical, late covers will rub on the bolts of the earlier pulleys. Do you mean the 3 x M6 bolts which hold the pulleys to the hubs? ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
yup, I fitted an earlier pulley on my inlet cam to make it easier to adjust, but they caught the inside of the later covers.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
so ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
there's actually three different covers, one early type till RP 7664 with the slider, then two with the nuts changing at RP 08547.08547 is when the single bolt pulleys came in. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stan_306gti6
I stand corrected then...Seeing as I did your cambelt last week Matt I can confirm that your engine has the later style pulleys, so you will be looking for a cover which is post build code 08547. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
stan_306gti6 wrote: I stand corrected then... Said the man with the orthopaedic shoes. ________________________________________ ![]() |
mattgti6phase2
Is it the later 08547 one you have Dan? ________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
that's not a part number, its the RP number of the changeover ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
honestly3k
Seasoned Pro Location: Berkhamsted Registered: 06 Apr 2009 Posts: 2,390 Status: Offline |
Its a sad day when Matts 'Wanted Cambelt Cover' is the busiest thread on the forum ![]() ________________________________________ ''Oh, it does handle like a golf!'' Why drive a Golf....when you can drive a GTi-6? |
It's from a 2000 car so I'd suspect so.________________________________________ ![]() |
