Author Subject: Is this right?
Pug bazza
Hello guys, I seem the coolant bleeding thread already posted, but just wanted to clearifiy few things, I bled the coolant system it was heading to 90-90+, when stationary but when driving it came down, but the end result I got when stationary was 83-85 would this be correct, there was air in the system as bubbles was appearing from the bleed valve on rad when bleeding, thanks
Posted 26th Aug 2013 at 19:04
The car has an 83 degree stat so it shouldn't drop below that when up to temp and driving. It sounds like you did it correctly. Smile
Posted 26th Aug 2013 at 19:16
Pug bazza
Thanks stan so now should drop below or rise more than 83 when stationary thanks, but when driving it would drop below I imagine
Posted 26th Aug 2013 at 19:30
Pug bazza
Shouldn't drop below 83 or rise more than 83 when stationary,sorry last post it come up with 'SHOULD'
Posted 26th Aug 2013 at 19:32
RetroPug
Surely it will rise until the fans come on at 110ish if left stationary as the coolant isn't being cooled by anything if you're not moving and the engine is still getting hotter if it is still running.
Posted 26th Aug 2013 at 19:35
fans come on well before 110, stop light comes on at 110!! from memory 92 is low speed 101 is high speed.
Posted 26th Aug 2013 at 19:43
RetroPug
I hear and feel them when high speed comes on and remembered it was 100andsomething but yeah just realised they obviously do come on before the red.
Think my memory's just patchy. Thanks.
Posted 26th Aug 2013 at 19:50
On a twin fan system the low speed fans come on at 97 and the high speed kicks in at 107...
If the vehicle is being driven, the temp should be around 83-85 on the gauge, once you're stationary then it will obviously go up. Yes
Posted 26th Aug 2013 at 20:39
scotzman
My temp sits about 80, I thought this was low so changed the thermostat..still 80, replaced the temp sender and no change.
Posted 26th Aug 2013 at 20:46
It may show 80, but that is correct as the gauge isn't exactly spot-on accurate.
Posted 26th Aug 2013 at 21:18
Pug bazza
Thanks guys help much appriciated
Posted 26th Aug 2013 at 21:26
RetroPug
Hm wasn't far off then.
Posted 26th Aug 2013 at 21:32
