Author Subject: leaking sunroof
pebbles167
Noticed this morning that I have a pretty severe leak, much to my dismay.
Drivers seat was soaked and on a left had bend on the road to work a stream of water poured all over my legs. Appeared to be coming from the central interior light/sunroof controls.
I'll pull it apart and have a look over the lot, is there anything in particular I should be keeping ab eye out for or any common problems.
Cheers,
Pebbles Thumbs up
2005 Peugeot 206 GTI 180
2008 BMW K1200R
Posted 6th Sep 2013 at 09:01
superchargedblack1997gti6
My phase 1 started doing this was a case of fitting a new aerial base mount! the seal goes around that and then collects in the interior light! hope that's of use.
Posted 6th Sep 2013 at 09:03
jimmyrallye
^ yeh this or whack some mastic round the aerial base solved my problem
Posted 6th Sep 2013 at 12:29
calibra306
Did my ariel base but was not that.
Mine was the metal frame that looks like its sealed to the glass that then sits on everything to make it move.
I had to remove lining then washed thecar to see where the water was running in. A drop of sealant along the frame corners attached to the glass and sorted.
Sunroofs coming out as soon as I get me carbon blanking panel!
V6 Power!
Faster I can go the better!
Posted 7th Sep 2013 at 22:17
Lecktorious
aka G.
There are 4 drains on the sunroof, if the aerial base isn't leaking one of the drains could be blocked.
'98 Nile Blue 306 GTi 6
Posted 6th Sep 2013 at 18:27
pebbles167
Thanks guys, helpful replies. ill try some stuff today based on the advice.
Thumbs up
2008 BMW K1200R
Posted 7th Sep 2013 at 09:20
RetroPug
If the drains are blocked you can clear them with a compressed air line. This happened to my old 106.
Posted 7th Sep 2013 at 09:33
jimmyhackers
i had this.... removed the infrared sensor cover to reveal it was a tiny swimming pool Smile
aerial was leaking. sealant fixed it
Posted 8th Sep 2013 at 13:33
brand new aerial base is like £5.20 from stealers. comes with that weird gun gum stuff does the job.!
Posted 8th Sep 2013 at 13:45
