Author Subject: PAS removal
Niall
Removing my PAS pump. Does anyone know the new belt length? Its a AC model so i should be ok with just going right over the alternator and back down yes?
Posted 7th Sep 2013 at 20:38
Mentalist! Razz
Wouldn't want that one a road car!
Posted 7th Sep 2013 at 21:49
Niall
Who said I won't be running pas? Lol converting to an electric setup to make room for my charger.
Posted 7th Sep 2013 at 22:04
With what tensioner?Dunno
As the auto tensioner won't work with the belt running like you want to above,and the Rallye non-aircon tensioner won't eitherNo
Or are you keeping aircon pump?Dunno
Posted 7th Sep 2013 at 22:31
Niall
I was going to keep the air con pump for the time being until I can afford to get a rallye set up. Sure I had a quick look and with the air con pump in place, the auto tensioner should still work or am I just being a retard?
Posted 8th Sep 2013 at 10:01
Ahh i see what charger you got then?
Posted 8th Sep 2013 at 12:23
Niall
Eaton M60. Going down a completely different route to the typical Rotrex one Smile
Posted 8th Sep 2013 at 21:01
IvayloPavlov
I am interested too.Does somebody has experience with Saxo/106 pump?I have one of this.
Posted 8th Sep 2013 at 22:00
Yeah if keeping aircon pump auto tensioner will workYes
As this is how you tension the aux belt when you relocate pas pump to aircon pump position when fitting itbs etcWink
If the aircon pump has the same size pulley as the pas pump and is positioned in exactly the same place as the pas pump is when its relocated you want a 6PK1103 Aux beltThumbs up
Posted 9th Sep 2013 at 07:00
Niall
AH nice one cheers mate
Posted 9th Sep 2013 at 17:12
IvayloPavlov
@Niall did you find correct belt?
Posted 15th Dec 2013 at 21:53
IvayloPavlov
I found Smile
Could be shorter but not longer.
Posted 21st Oct 2014 at 20:54
IvayloPavlov
Work perfect.
Posted 7th Dec 2014 at 00:44
