Author Subject: 205 GTi Thermostat connector
devere
Anyone who has or had a 205 gti, got the metal pipe that goes on the thermostat housing, that the top radiator hose goes onto please? Its instead of the standard gti6 one that uses the join with funky metal spring clip.
Let me know. Cheers.
Posted 12th Sep 2013 at 22:25
beez_neez_gt
I think iirc you can buy a similar one from Pug its plastic but im sure can be modified to fit with RTV etc.
Here you go mate hope this helps.
http://www.ebay.co.uk/itm/peugeot-205-1-9-1-6-gti-alloy-thermostat-housing-/121097300990?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3APeugeot%7CModel%3A205&hash=item1c31f62bfe
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 12th Sep 2013 at 22:41
devere
Oh cool.
So that ebay one, the radiator hose outlet off that would be the compatible part to put onto mine?
Excuse the ignorance, im not a 205 buff, and have no knowledge of the compatibility of the 205 parts. Im assuming that is a gti part, either 1.9 or 1.6, being the same part..?
Posted 12th Sep 2013 at 22:50
beez_neez_gt
Yes 1.6 or 1.9 use the same one, its the one with the pipe outlet attached to the thermo with like half moon shape will fit straight on mate. People use the same one on 6 engines when doing a conversion. Its the part bolted on at the bottom right hand corner of the picture. Thermo is just upside down or wrong way round is all LOL
Pug fee`ver,
Posted 12th Sep 2013 at 23:07
monkey
Not 100% sure what your after but I have a 1.9 gti plastic thermostat housing that the top hose fits on to. £8 posted
Posted 13th Sep 2013 at 06:44
allanallen
Some if not all of the plastic outlets put the pipe at a different angle to the metal outlet so be careful what you're buying. The metal one is NFP from peugeot, if you try farmer over on drivers he can do a worldwide dealer search for you for a new one.
I take it you're using a Bbm thermostat housing adaptor?
Facebook
Posted 13th Sep 2013 at 07:09
devere
Yeh thats the plan. Probably didnt word the advert overly well as couldnt think of how to out it at the time!
In that ebay link, that aluminium hose outlet should be the right one im guessing?
Posted 13th Sep 2013 at 09:22
jorg
Is it one of these you need Martin?
306 2.1 S16 Tarmac Rally Car
Posted 13th Sep 2013 at 09:43
Yup
Posted 13th Sep 2013 at 10:05
devere
Yes Geoff. Thats the bit. Basically just that bit to bolt on to the bbm adapter so I can run a normal silicone top hose, rather than the gti6 spring clip fitted one.
have you been hoarding again?! Haha
Posted 13th Sep 2013 at 10:08
jorg
they were on bbm adapters i had. just a small part of the junk i have gathered over the years.
have sent you a pm Thumbs up
Posted 13th Sep 2013 at 11:20
