displaying posts 101 to 125 of 139
Pages (6): first .. 4 [5] 6
Author Subject: Uprated 3rd & 4th Gears for Supercharged/High Torque/Track C
russbez
Post #101
no its not easy to pull gearbox apart?
My Rallye project thread
Posted 9th May 2014 at 09:36
superchargedblack1997gti6
Post #102
Think to fit its a bit of a pain and you'll need gear pullers?
Posted 9th May 2014 at 09:37
Post #103
Thought so.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 9th May 2014 at 10:01
russbez
Post #104
ahh? someone put gearbox together for you mate?
just picturing pulling a gearbox apart and everything pings off in different directions LOL
Posted 9th May 2014 at 10:10
hugovox
Post #105
Well, my mechanic said he doesnt had any problem. Im going to collect the this afternoon.
Posted 9th May 2014 at 18:34
Post #106
Guess it's fine to do if you know what your doing and have the correct tools ? Standard socket set is not gong to cut it me thinks
Posted 9th May 2014 at 18:53
Post #107
Sledge hammer Should take the box apart
Posted 9th May 2014 at 19:04
Post #108
actually, you'll get quite far with just a socket set and a small pointy screwdriver a hammer and some punches, as long as said socket set has a 12 sided 28mm socket in it.
Posted 9th May 2014 at 20:52
hugovox
Post #109
Well, i have collected my car today and i have to say that the kit its amazing, the sound and the gearchange its very fast, the only thing im worried about its a clicking sound when the car its in neutral, like something is loose, but my mechanic said thats normal.
I have tested the car at the main avenue in here, and everything is normal.
In a few days ill put a video in youtube so the forum can have an idea of my happiness.
Thanks ASH!!
Posted 15th May 2014 at 20:59
Post #110
Video of the gearkit in action
Posted 22nd May 2014 at 22:04
hugovox
Post #111
Hi everyone, sorry for the delay in hanging the video but I've been kind of busy with flights. I can say for the moment that the gearshift can be made with the clutch but have to be quick, so the engine dont lose to much Rpms, the more delay the more damage to the dogs, the faster the best, just slight pressure on the lever and when the clutch enter the gearshift will enter very easily. To make the shift without the clutch you have to remove the engine load, this is to remove the pressure on throttle just a moment and shift to the next gear, fast and accurate, then accelerate. Here you can also make a slight pressure to the lever and just when the engine drops Rpms the next shift will enter fast. To downshift you need to give it a little pressure to the accelerator just a dab to increase the rpms and at that moment move to the next gearshift.
I have used the car a couple of times and no worries, the gearbox works fine.
Well guys, i dont have time this week to record the video but I have free weekend so I hope to do the recording this sunday.
Best regards from Peru and sorry for the bad english.
Posted 9th Jun 2014 at 05:48
rallyestyle
Post #112
Nice review Thumbs up
May be a silly question but it sounds like normal shifting through the replaced gears is not advised? Dunno
Just Drive It
Posted 9th Jun 2014 at 15:19
hugovox
Post #113
Hi mate, if you make the shift quickly and accurately you'll hear a light clunk (using the 2 methods, using the clutch but doing the gearshift very fast and the other method lifting the throttle pedal just a moment allowing the engine load to be removed, make the gearshift and accelerate) but if you use the clutch and make the shift in the normal way, or very slowly allowing to decrease the rpms too much you'll hear and feel like something is going to break down.
I recommend a quick shifter, solid gear links and a lightweight flywheel.
Greetings
Posted 9th Jun 2014 at 15:50
pebbles167
Post #114
Was there ever any interest to make more of these?
2005 Peugeot 206 GTI 180
2008 BMW K1200R
Posted 16th Jun 2014 at 00:01
rallyestyle
Post #115
I would think after a bit more feedback there will be. Wetehr Ash can get any more made im not sure Dunno
Just Drive It
Posted 16th Jun 2014 at 08:54
Post #116
anyone can get them made, just depends if you can afford the costs of a one off.
Posted 16th Jun 2014 at 10:27
pebbles167
Post #117
I could probably afford it, but id rather not LOL
How much does a used dog gear kit go for roughly? Didn't a 6 speed one sell recently for around £1700?
2008 BMW K1200R
Posted 16th Jun 2014 at 11:08
Post #118
not sure on 6 speed, but a drenth dog gearset is about £2500
Posted 16th Jun 2014 at 11:11
pete_rallye
Post #119
The Sadev one on ebay went for £2k which was pretty cheap I thought, but they are only rated to around 180lb/ft so a SC engine would obliterate it.
Theres a vid here> https://www.youtube.com/watch?v=rYwAIs8Bwpo of me using my dog box but its not very clear, and it looks like I am using the clutch occasionally too.
Main thing with dog boxes is to be firm and positive in the gear change, don't dilly dally because the dogs aren't forgiving at all like a syncro is. If you crunch the gears you'll knock the dogs off which will inevitably end up mashing the rest of the box. If you're going to do clutchless down changes then do all you're braking before changing down so the load on the dogs is minimal. You can even left foot brake then a dab of throttle to unload the dogs and drop it down a cog although it'll take a lot of practice! Up changes are much easier and less likely to destroy your dogs, just load the gear lever then off the gas and back on again and the gear should change nice and positively.
Lap of the 'ring
Posted 16th Jun 2014 at 11:21
pete_rallye
Post #120
I know a man thats been trying to get hold of a new final drive for his but Drenth won't make one so not sure they are still making the dog gear kits. Only people I know is Sadev but they are limited in there strength and you can still buy the original Pugsport ones like I use but they aren't cheap and I don't know what torque they are rated too, Avanti motorsport do a kit also but not sure if its a dog kit or not.
Lap of the 'ring
Posted 16th Jun 2014 at 11:31
pebbles167
Post #121
Thanks for the info guys Thumbs up
I was thinking of getting either a dog gearset or complete box to start hill climbing late 2014/early 2015. The rallye id use is a standard engine with PT80 cams, unlikely to have any more than 170bhp so torque shouldn't be an issue.
If another group buy for the 3rd and 4th started Id be intetested. Seems like a good compromise.
2008 BMW K1200R
Posted 16th Jun 2014 at 11:53
Post #122
bacci romano do 6speec kits
Posted 16th Jun 2014 at 13:14
pebbles167
Post #123
Good shout on the Bacci Romano, £4500 will get you a full set by the looks of it.
2008 BMW K1200R
Posted 16th Jun 2014 at 17:36
pugheaven
Post #124
The gear company made a few spare sets so if you speak to ash he will be able to get you a kit
Posted 16th Jun 2014 at 20:36
pebbles167
Post #125
Thanks for the heads up Smile
2008 BMW K1200R
Posted 16th Jun 2014 at 20:59
