displaying posts 26 to 40 of 40
Pages (2): 1 [2]
Author Subject: Engine work before low boost
c_j_m
I'll nice and add some input to to the thread too.
I'd suggest doing the bottom end and crank bearings too, just cos there easy to get to and you'll be running more power through potentially worn items.
Posted 8th Oct 2013 at 20:55
Don't forget the little 'hockey stick' seals in the number one end capWink
How many miles has the lump done?Dunno
If it was mine I would be dropping crank out,getting it inspected and at the minimum fitting new standard sized shells after the crank being polishedYes
And for peace of mind I would bang a set of ARP rod bolts inThumbs up
And stripping and checking the oil pumpBig grin
LOL
Great minds......Thumbs up
Posted 8th Oct 2013 at 20:56
c_j_m
Great shout on he arp's too.
Posted 8th Oct 2013 at 20:57
6waysforward
All of the above is right but there have been a few low boost and lightened flywheel issues.
I have both boost and the lightened flywheel and i get stalling and occasional running issues which we think is down to the map.
When the ecu's are mapped, they don't factor in a lightened flywheel. ( correct me if i am wrong )
You would have to confirm with rich tbh.
While the engine is out, put a new headgasket on it to, can't hurt.
Posted 8th Oct 2013 at 21:00
ryangti6
jamiek_uk2000 wrote:
It looks like CJM hijacked my thread and beat me to it
He's done you a favour imo, other than being re usable they are a waste of time/money.
As others have said it would be worth doing the shells and good shout on the oil pump, I've stripped good engines that are still surprisingly full of tiny metalic particles from engine wear
Ryan
jamiek_uk2000
How easy is it to do the pump? How do you get to it? Through thevsump Isit?
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 8th Oct 2013 at 21:04
c_j_m
Sump off 2 10mm bolts holding a cover on then 3 11mm bolts holding the pump on. Also 1 more 10mm holding the pick up on iirc.
Posted 8th Oct 2013 at 21:07
ryangti6
Yeah sump off, unbolt the pump, there is a little spacer plate underneath it that you need to slide out then you will have enough movement to get the chain that drives it off, very simple when It's in front of you.
Ryan
Posted 8th Oct 2013 at 21:10
jamiek_uk2000
Post #35
I'm debating just dropping it an my local engine builders, I know him so it won't be massively expensive. I'm not too sure if all of this is something I can delve into. Debating here. Hmmm
Looking for:
VTS P1 Rack
PR1.2 16"
jimmyrallye
Post #36
Save yourself the money and heartbreak and buy a r26 Smile
Posted 8th Oct 2013 at 21:27
jamiek_uk2000
Post #37
Don't like the R26 at all. If I was buying anything then it would be a CTR or an S2000 (Jackson supercharged, either one)
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 8th Oct 2013 at 21:35
jamiek_uk2000
Post #38
The guys at Peugeot are laughing at me when I go in to pick up bits now. They can't understand what I'm doing all this to a 306. I've not even bought half the stuff from them, most of it is uprated so if they knew how much I had spent the would be in stitches
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 8th Oct 2013 at 21:38
jimmyrallye
Post #39
You never get back what you put in to it been there done that .. Now if I wanted something fast would buy one already tweaked and a few suspension mods I've blown thousand on coilovers in my life lol
Posted 8th Oct 2013 at 22:28
jamiek_uk2000
Post #40
All my suspension gear has been second hand off the forum, the only new items have been ball joints and Rich_W roller bearings. Everything else has been off here.
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 8th Oct 2013 at 22:43
Pages (2): 1 [2]
