Any ideas? Not certain what was causing it.
Rallye Race Car
| Author | Subject: Soft brake pedal when cold |
demondriverdan
Just remembered something odd about the brakes on the race car when we were out at Brands last week. Once we'd done a few runs in the car, each time you went out the brake pedal was quite soft but after a lap or two would get much firmer and back to how it was a the beginning of the day.Any ideas? Not certain what was causing it. ________________________________________ Rallye Race Car |
rikky
what fluid are you using?________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
demondriverdan
Dot 4________________________________________ Rallye Race Car |
What pads are you using?________________________________________ ![]() |
demondriverdan
dangti6 wrote: What pads are you using? Standard Brembo pads that came on the Megane 225. I have plans to upgrade but didn't think the pad would cause the problem? ________________________________________ Rallye Race Car |
stan_306gti6
Try a fluid change first and ensure you bleed the system properly.________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
demondriverdan
It's a new system as I replaced all the lines when I removed the ABS. There are no leaks and we've bled it about 5 or 6 times to make sure all the air was out.________________________________________ Rallye Race Car |
Hawkesfire
Regular Location: Stockton on tees Registered: 26 Mar 2013 Posts: 180 Status: Offline |
If you have a bias valve have you got this opened up enough to let fluid through also could be a bent bracket on your callipers so the pads have to pull up before they work correctly as i had this on the back of a Mk2 escort when someone had fitted a rear disc conversion and did not get the brackets lined up straight before they welded them to the axle !!!!!________________________________________ 206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!! |
Could also be the master cylinder clearance.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
demondriverdan
Hawkesfire wrote: If you have a bias valve have you got this opened up enough to let fluid through also could be a bent bracket on your callipers so the pads have to pull up before they work correctly as i had this on the back of a Mk2 escort when someone had fitted a rear disc conversion and did not get the brackets lined up straight before they welded them to the axle !!!!! We've got a bias valve, around the mid-position so some fluid should be going in. Bent bracket doesn't sound too good! Will check them. ________________________________________ Rallye Race Car |
demondriverdan
phillipm wrote: Could also be the master cylinder clearance. Master cylinder clearance? As in how far the master cylinder moves? ________________________________________ Rallye Race Car |
