Author Subject: Supercharger
p-silva21
Hi guys, I´ve fitted yesterday my supercharger kit that I bought from Rich (aka Fordygti) and when i started it up the idle was at 3k... there are only 2 things that I maybe have to check later that are the TPS and the slimline wiring, but probably the TPS wiring is wrong am I right?
Pedro
Posted 21st Nov 2013 at 10:44
fordygti
Should be a problem with the kit as I came of my car working and straight to you. Check all you connections from were you extended the loom. I had a couple of problems at first due to s**te connections.
98 onyx black 306 Rallye
58 black Volvo c30 sport
Posted 21st Nov 2013 at 11:29
Check all the boost pipes too.
Posted 21st Nov 2013 at 12:49
superchargedblack1997gti6
yep agree with Chris could well be a boost leak!
Posted 21st Nov 2013 at 12:50
pete-gti
I no this mite sound silly, but your throttle cable ain't some how pull opened?
Check all boost connections
Go over all your wiring again,
Can't be much you will find it:-)
Posted 21st Nov 2013 at 14:23
pete-gti
Do a ecu reset
Posted 21st Nov 2013 at 14:25
Moved to Engines. Smile
Posted 21st Nov 2013 at 14:54
p-silva21
Thanks for your replies! Tightened up all the hose brackets again, checked if there was some pipe in wrong position and nothing new... when I return home tonight I´ll check all the wiring too Thumbs up
Posted 21st Nov 2013 at 16:30
p-silva21
Yes Peter I have the throttle bodie full closed Smile I´ll reset the ECU first to see if the problem is the ICV. (remove the ECU during 10 mins right?)
Posted 21st Nov 2013 at 17:00
p-silva21
Thanks Stan, forgot to put the right subject Thumbs up
Posted 21st Nov 2013 at 16:54
Niall
Remove the inlet and make sure there is no old gasket stuck to both the head face and inlet face. I had this issue, cleaned up both faces, new gasket and was spot on.
p-silva21
Good point too Niall, tomorrow I´ll check it and let you know Thumbs up
Posted 22nd Nov 2013 at 00:34
marco gti6
Nice to see another Portuguese member on here. When i got my car back from the conversion i had issues with the throttle cable as well which would influence the idle. Make The TPS goes from closed all the way to fully opened as mine did not.
Bem vindo and get some pics up Thumbs up
Posted 22nd Nov 2013 at 10:26
sounds like a air leak and it's sucking in air from somewhere which is letting it idle high
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 22nd Nov 2013 at 11:06
p-silva21
Obrigado Marco Thumbs up so, tried to find some air leak, cleaned the PTFE and nothing, then I looked well at the ICV..... forgot to tightened the screws Unsure stupid fail. ECU reset and worked fine Thumbs up and yes, have to make sure that everything is well tightened again!
Thanks for all your help!
Posted 22nd Nov 2013 at 18:32
Doh
Glad it's sorted now. Thumbs up
Posted 22nd Nov 2013 at 20:08
