Author Subject: pug1off quickshift
osm2121
I recently bought the pu1off´s gear linkages, and for a bit more, came with the quickshift.
Has anyone fitted this quickshift? Is it any good? The bolt to fit it seems it wont handle it
And, if someone has a guide for installing it, i´d appreciate it!!!
Posted 10th Dec 2013 at 23:09
I think it slides over the bar from the gearbox and you connect the large rod to that instead ? Further down the gearbox bit you get it the shorter the shift
Posted 10th Dec 2013 at 23:22
mattgti6phase2
This. Also use thread lock on the grub screw. The position (angle) of the quick shift also determines if the throw is shorter one way or the other.
I run this quick shift and have had no problems with it at all. Just use some sand paper on te selector shaft and then the quick shift will just about slide on, it should be a fairly tight fit.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 14th Dec 2013 at 18:08
osm2121
Thanks guys! Gonna fit it somewhere soon i guess
Posted 18th Dec 2013 at 04:09
osm2121
I remeber I read somewhere on the forum, how to regulate the gear linkages to get smoother gear changes, by getting shorter or larger each linkage.
But i just can´t find the thread where i read it.
Can someone help me with that?
Thx
Posted 23rd Feb 2014 at 15:34
osm2121
No one???
Posted 25th Feb 2014 at 13:31
