| Author | Subject: Rear Anti roll bar |
gareth softley
Newbie Location: purley Registered: 23 Sep 2013 Posts: 21 Status: Offline |
Started stripping down my rear torsion bar today. With the two 13mm bolts removed from the end caps on the ARB so it is free from the beam itself, should I be able to turn it freely??? may not be massively important but would be good to no. |
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
Yes it should be able to turn freely |
gareth softley
Thought so, am I right in thinking if this was seized solid, it would stiffen up the rest of the rear suspension? I use the car for rallycross and last few meeting I haven't been able to stop the ass end bouncing I wonder if this could have been causing it |
jord294
When you removed the m8 bolts, did they come out with ease, or under pressure.As it could be a sign your trailing arm is seized in position compared to other side ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
Continue the strip down by popping the caps off with a ford wheel bolt/head bolt or whatever you have with the correct thread and see what the inside of the shafts are like.________________________________________ ![]() |
