Author Subject: supercharger belt accuracy
Niall
How much can i get away with with the pullies not lining up exactly? I know they have to be pretty much perfect and I've got the belt on mine today to find the charger is sitting about 1-2mm further out than the other pullies. How much of a problem is that going to cause me? If it really does need to be 100%, i can just pull the pulley off the shaft slightly to line it up and whilst i can't see that being an issue, id rather just leave it all be.
Posted 27th Dec 2013 at 15:52
tvrfan007
2mm will take a rib off the belt. Years ago I changed my hdi sump and forgot the washers on the Aircon pump, it was only 2mm but would fetch a rib off the belt within hours. I fixed it the next day but already needed a replacement belt lol.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 27th Dec 2013 at 18:03
Niall
Right fair enough. I know what tomorrows job will be then! lol
Posted 27th Dec 2013 at 18:54
allanallen
Yep just echoing what's been said but it needs to be bob on or you'll just throw the belt off.
Facebook
Posted 27th Dec 2013 at 18:57
Chargers take a lot of power to turn when under load making boost so has to be spot on. Looks like good progress though Niall Thumbs up
Posted 28th Dec 2013 at 00:40
This will be interesting to see a finished result, seeing as you've gone down a different route to Lynx.
Good luck with it. Thumbs up
Posted 28th Dec 2013 at 08:20
allanallen
There's 5 eaton/peugeout conversions that I know of?!Thumbs up
Facebook
Posted 28th Dec 2013 at 09:45
On this forum? I haven't heard about them...
Posted 28th Dec 2013 at 09:52
allanallen
LOL you don't get out much then stan?!
Other than mine there were 3 (almost 4, that irish guy if you remember?)on the forum but they've disappeared like everyone else since membership fees came in Sad
There's 2 gti6 205s with eatons over on drivers and another in the pipeline that I know of.
Facebook
Posted 28th Dec 2013 at 10:31
Ah right, I see.
I didn't spend much time on the forum during 2009/2010 before membership fees came in as I spent all my time working/driving the car as opposed to being on here, lol.
Also, I'm not a member on drivers, so I didn't know that. Fair play to those who have done it though. Smile
Posted 28th Dec 2013 at 10:46
Niall
Right, ill get the hammer out and get this fixed today then Big grin
Posted 28th Dec 2013 at 10:47
rallyestyle
You know what they say about doing things properly, a litle time now will save you numerous headaches in the future Thumbs up
Just Drive It
Posted 28th Dec 2013 at 17:34
Niall
Yeah definitely! Id much rather do it properly first time round (well as properly as you can out of a 8x7 shed!). Just wasn't sure on the tolerances you could get away with Smile
Posted 29th Dec 2013 at 21:50
Did you manage this successfully then?
Posted 30th Dec 2013 at 07:54
Niall
Got it as close as possible using a straight edge although its difficult when the pullies are so small to line it up against. Will run it and see if i have any issues then adjust from there on.
Posted 30th Dec 2013 at 17:56
Hawkesfire
Hi
I used a laser line from B&Q when i built my old c30-94 charger bracket
Marty
206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!!
Posted 31st Dec 2013 at 17:31
Woodstain
I'm doing an eaton m45 on mine, used to run a lynx before I owned it, so far I've only removed the manifold for cutting, and engine mount to be cut and re welded to form a bracket for the charger. I'll try and get some pics on if anyone's interested?
Posted 2nd Jan 2014 at 14:00
Niall
Would be good to see pics and see how your going about it. Ive got pics of how I've done it in my project thread.
Hawkesfire, i like the idea of the laser line. I've got one in the shed so will double check it all with that at the weekend!
Posted 2nd Jan 2014 at 17:36
