| Author | Subject: all three brake lights not working |
astor gray 2014
Junior User Location: cork Registered: 01 Jan 2014 Posts: 91 Status: Offline |
Hi all 3 brake lights not working on my 306 rallye any ideas bulbs changed relay changed but still not working |
Switch behind pedal is a good place to start ![]() ________________________________________ ![]() |
jord294
How about brake pedal switch ??________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
astor gray 2014
That was changed too might wiring under dash as might have been disconnected when dash was put back |
rikky
switch or dash loom earth in driver footwell________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
astor gray 2014
A cool i will check it out today thanks for help |
stan_306gti6
Disconnect the switch and see you have powered being supplied to it with the ignition on.If so, then the issue lies with the switch or further downstream from it towards the light units. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
jimmyboycheck
Regular Location: bournemouth Registered: 19 Apr 2009 Posts: 121 Status: Offline |
Fuse?________________________________________ Silver 6 |
stan_306gti6
jimmyboycheck wrote: Fuse? He needs to see if he has power at the switch first, because if he has the fuse is fine. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
astor gray 2014
There is power to switch is there earth wire and there relay |
I put a new switch on and left the old one in the car ? Is there an earth behind the rear quarter panels ? It's my old rallye by the way ! Glad you got back to Ireland ok bud |
astor gray 2014
Thats what i was looking for Will look for tomorrow ran a multimeter but no power to lighting wires yeah i was thinking that |
astor gray 2014
astor gray 2014
Still no luck but airbag light off just had to reconnect wire |
astor gray 2014
THanks ricky will check that |
I'm pretty sure it's a wiring issue behind the dash after doing the heater matrix ? I pulled the dash forward to get to the matrix but left the the switch connected. |
astor gray 2014
A cool ill have to check that tomorrow thanks |
astor gray 2014
All sorted it was the fuse and the second switch did the abs so all Sorted |
Happy days glad it's all sorted. Might want to check reverse light switch as I think it needs sorting as well |
astor gray 2014
A ok cool ill have a look next drive shaft seal and engine mounting near gearbox need something good hard rubber omp maybe ? |
stan_306gti6
Glad it was a simple fix. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
