Author Subject: positive battery connector
martinh
Does anyone know if anywhere other than Peugeot sell the the threaded part that pushes over the positive battery terminal? Or what they're called? Have tried searching with a few different terms but no luck! Mine has only got a few teeth left and would like to replace it!
Posted 9th Jan 2014 at 21:18
eBay
Posted 9th Jan 2014 at 21:22
Posted 9th Jan 2014 at 21:23
martinh
Thanks mate. Have searched ebay but didnt find that! Will order a couple I think! Such a poxy design! !
Posted 9th Jan 2014 at 21:26
Swap it for a later design ?
Posted 9th Jan 2014 at 21:29
martinh
There's a later design? !
Posted 9th Jan 2014 at 21:40
scotzman
That ebay listing is for a -ve terminal, they are smaller than the +ve
Posted 9th Jan 2014 at 21:48
martinh
Good point! I only looked at the picture!!
Posted 10th Jan 2014 at 06:58
Later design is a clamp. Personally I prefer the screw on ones.
  • Posted 10th Jan 2014 at 07:43
    I agree. Yes
    Posted 10th Jan 2014 at 19:57
    i hate them and have always put normal ones back on
    how about that
    Posted 10th Jan 2014 at 20:03
    jimmyhackers
    hm..... im afraid i agree with rikky.
    half of the peugeot specific things make life awkward and stressfull.
    id also mention i managed to remove about a foot of wire from the original battery loom. on a stanny car it doesnt help but if youve relocated your battery every cm of wire counts.
    Posted 17th Jan 2014 at 17:52
    6waysforward
    The threaded castle battery connectors always corrode and break up. I ditched mine on my old ph2.
    The clamp on the later cars is also very s**t. Again i cut them off and replaced them with some from my local motor factors for less than a tenner. Job jobbed Thumbs up
    Posted 17th Jan 2014 at 20:22
    The threaded castle connector doesn't corrode if you look after it and not drive the car in salty weather.
    However, if it's an all year round vehicle then I can see why that might happen, try some anti corrosion grease on it for those which still have the connector fitted. Smile
    Posted 18th Jan 2014 at 08:23
    Mustv'e got a s**t one never had a problem on mine.
    Posted 18th Jan 2014 at 23:30
    Never had a prob with the later type either ? Plus it's easier To change the battery
    Posted 19th Jan 2014 at 00:20
    6waysforward
    Erm.... i live by the sea mate Smile
    Posted 19th Jan 2014 at 17:30
    Ah yes, of course you do. LOL
    (Note to self: Never buy 6waysforward's car, it'll be rotten as hell...Laugh)
    Posted 19th Jan 2014 at 17:49
    6waysforward
    Tis ok, it's immaculate underneath and under the sill's.
    Oh and i wont sell it. Keeping it for a sunday drive in 40 years time with my flat cap and pipe.
    Thats if its not rusted away by then anyways.
    Posted 19th Jan 2014 at 18:17
    mattgti6phase2
    So following on from this i have recently discovered my neutral cable has seen better days (the end connecting on to the gear box) i will replace the cable that also connects from the gear box (smaller cable) to the chassis leg.
    Does anyone know the thicknesses of these 2 cables and where i can get a connector (terminal end) and connectors for the gear box and chassis leg also?
    Many thanks Matt.
    Team Nile 6 Superman
    Team: 40.2 MPG Smile
    5 x a 306 owner!
    I truely live for the 306 ®
    midweek madness Tee hee
    Posted 21st Jan 2014 at 16:31
    I've a used negative cable Matt if it's of interest?
  • Posted 21st Jan 2014 at 16:45
    mattgti6phase2
    How used is used? I don't want the same troubles a year or so down the line sir.
    5 x a 306 owner!
    Posted 21st Jan 2014 at 18:01
    I'll get a cable whisperer to question how many times it's been undone.
    LOL
    I'll get a picture for you Thumbs up
  • Posted 21st Jan 2014 at 18:13
    mattgti6phase2
    LOL you know what i mean.
    5 x a 306 owner!
    Posted 21st Jan 2014 at 19:27
