Author Subject: 6 window switch
nadine
Ok so I have a bit of a strange one. My current 6 window switch is cosmetically damaged and the button for the drivers window doesn't work. The passenger button and electric mirror part all work. I have purchased 3 different window switches now, told they are working but when I fit to my car they don't. Surely I can't be that unlucky to have bought 3 non working switches? Could there be a different issue? Don't want to keep.buying if they are never going to work
Posted 19th Jan 2014 at 15:31
calibra306
There are different switches dependant on year/phase.
The connecting plugs also vary. Ie mine is a phase 2 which when you look at the under side of switch it only has 4 pins where the later has more connecting pins
V6 Power!
Faster I can go the better!
Posted 19th Jan 2014 at 15:35
calibra306
I meant different switches as in the internal workings and the connecting plug.
cosmetically they all look the same
V6 Power!
Posted 19th Jan 2014 at 15:36
nadine
Ah ok so for example a phase 3 switch wouldn't work in a phase 2?
Posted 19th Jan 2014 at 15:38
nadine
Oh and I see you make black masks Smile
Posted 19th Jan 2014 at 15:42
Rich E Forum Admin
Correct. There's a mini-FAQ on this: http://www.306gti6.com/forum/showthread.php?id=74364
Posted 19th Jan 2014 at 15:45
nadine
Thanks Rich it's driving me mental!
Posted 19th Jan 2014 at 15:48
jimmyhackers
might be worth spending 20 minutes of your time cleanign the door plug pins on either connector side with a little peice of emery paper.
they have a habit of corroding/green gunking up.
Posted 19th Jan 2014 at 16:27
nadine
My drivers loom is currently greened up at the Mo. Would that stop just the drivers window button on that switch stop working? Bare in mind all other parts of that switch work
Posted 19th Jan 2014 at 16:42
scotzman
Are you sure its not the drivers window motor?
Posted 19th Jan 2014 at 17:09
nadine
I havnt checked the motor, wanted to try switch first as the obe I have no longer clicks. The new switches I have been getting don't work anything, even tho my exisiting switch does everything except drivers window
Posted 19th Jan 2014 at 17:36
