Author Subject: S16 with Gti6 Engine
p-silva21
Hi all,
I´m in negotiations to earn an S16 and as I have a spare gti6 engine, would like to know what do I need to swap the engines..
I´ve swapped my old 1.8 16v with the XU10J4RS engine but it was almost a straight in installation, I believe that the S16 wiring loom needs much more modifications. My questions is: Will it worth the patience/time (if there are too much wires to re-connect) or its easier if I just bought a gti6 wiring loom?
Cheers Thumbs up
Posted 22nd Jan 2014 at 20:45
jimmyhackers
sack off the orignal engine management system and fix in a MEGASQUIRT system
Posted 23rd Jan 2014 at 17:18
dcc
What the f**kkk
Just fit normal wiring for the gti6 Smile
205 GTI
Xsara HDI
Posted 23rd Jan 2014 at 19:52
pugheaven
Lol Jimmy hackers is full of s**t and never knows what he is talking about , as Dan said just use the 6 ecu and loom, my old grey car was an s16 once upon a time
Posted 23rd Jan 2014 at 21:14
p-silva21
Thanks for your replys Thumbs up yes, maybe I didn´t explain it in the best way.. I have the gti6 engine loom too, but will it work fine if I just plug the gti6 engine loom with the rest of s16 loom? What about the instrument cluster, can I just sawp with a ph2/3 it and it´ll work normally too? Dunno
Posted 23rd Jan 2014 at 22:13
pugheaven
Yep just plug and play, you can use your original cluster, only thing that won't work is the oil pressure gauge, lower rad hose might be different depending on what style connection you have on the rad
Posted 24th Jan 2014 at 10:49
if you use the engine loom it'll be fine, just bear in mind things like speedo drive / clocks. is the s16 cable driven speedo?
Posted 24th Jan 2014 at 10:57
p-silva21
Ok, thanks for your help, I´ll post here some pics if I bought the car Smile yes I think it is a cable driven speedo
Posted 24th Jan 2014 at 19:47
Was done very tidily in my S16 everything worked spot on bar the oil pressure sensor as mentioned. I didn't go the conversion though so can't really help with what they used. I had the 6 engine with the S16 box though. Was fuuuuun!
Posted 24th Jan 2014 at 19:56
pugheaven
My s16 was a late one which didn't have a cable operated speedo so you might be lucky
Posted 24th Jan 2014 at 20:17
jimmyhackers
if thats the case then pug heaven also knows exactly what hes on about all the time Smile
Posted 26th Jan 2014 at 23:04
