| Author | Subject: Power steering cooling pipe removal. |
Markie
Junior User Location: Porthleven Registered: 10 Jan 2014 Posts: 93 Status: Offline |
Hi guys, thinking about removing the power steering cooling pipe as it's rotten, i've read somewhere on here that people have cut it out and joined the two pipes up...this is probably a silly question but i'm just wondering what to use to join the two pipes up? Any help would be muchly appreciated. Thanks. |
One option:![]() The end of the cooling pipe chopped off. ________________________________________ ![]() |
Markie
Thanks cheers. |
eddy_gti6
It will only be surface rust. Good wire brush on a grinder should sort it out and a lick of paint________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Markie
I was thinking that but Its weeping in two places, one place being near the u bend, will have a closer look as I might be able to save the ubend. Thanks |
jord294
Iirc, pug heaven on here has an excellent powdercoated one for sale________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
Mine was a little more than surface rustBut as said I used a bit of the good steel pipe and joined the two return hoses directly under the reservoir, The one under the engine mount is flexible enough to bend it through 90, so you only need about 30-40mm of pipe and two hose clips |
Markie
thanks for the info guys, i'm guessing it would be easier to just bin the cooler than replace it? dangti6, have you noticed any problems since removing it? cheers. |
Markie wrote: dangti6, have you noticed any problems since removing it? cheers. That's a pic I stole. I don't have powersteering at all as I re shelled into a 205. ________________________________________ ![]() |
scotzman
Seasoned Pro Location: Dundee Registered: 24 Jun 2011 Posts: 1,408 Status: Offline |
I did mine a few months ago and haven't noticed any change, much easier than replacing the pipe too.________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
scotzman
jimmyhackers
Seasoned Pro Location: birmingham Registered: 14 Jun 2011 Posts: 1,302 Status: Offline |
im gonna make me sound like a dingle herebut power steering cooling?..... never knew i had it......where does the fluid go to cool? what is the mechanism/chamber that actually does the cooling? is cooling you PS fluid neccisary? ________________________________________ the world is changed by people in sheds |
scotzman
The cooling pipe is a big hairpin shaped pipe that runs along the front of the front lower crossmember and is prone to rotting, as for if its needed, ive done without mine for a few months without issue so far.________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
Markie
scotzman
Just jointed the two hoses as they come off the pipe with a plastic garden hose connector and two clips.________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
Markie
Haha sounds fairly simple! |
cully
the hard bit is doing it without loosing all the fluid |
stan_306gti6
Yep, I got rid of mine back in early 2008, never had an issue. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Markie
I think all my fluid will have leaked out by the time I get round to sorting mine. |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
I need to do this really.I assum you have to drian it first? ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
stan_306gti6
eliotrw wrote: I need to do this really. I assum you have to drian it first? You don't have to, but it'll get messy if you don't. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
RetroPug
While you're there you might as well replace the PAS fluid.________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
Clamp the hoses up before undoing the cooling pipe. Use vice grips if you don't have proper hose clamps. You'll lose less fluid then.________________________________________ ![]() |
eddy_gti6
Job on my to do list over the weekend before the new engine goes in.________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
whats the proper way of draining the fluid then?I suppose it needs replacing really. I certainly haent done that yet... ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
