Author Subject: when driving engine does accelerate
calumsaddler
When im driving my engine just stops it doesnt die but goes into tick over
say im going 40 mph and it will just go on tick over my mph needle drops to 0 but im still rolling but it still revs but nothing then it just kicks in again has anyone else had this problem
good to go!!
Posted 5th Feb 2014 at 10:00
gman
Sorry, but what you have said doesn't really make any sense. Perhaps restructure your sentence and someone maybe able to help.
Are you saying that your engine and rev counter are working fine, but that your MPH gauge stops working on occasion?
1992 Onyx Black 205 GTI-6
2005 Honda S2000 (Sold)
2002 Audi S3 (Sold)
2005 Clio 182 Trophy (sold)
Posted 5th Feb 2014 at 12:17
doon1988
If you mean what gman says then it could be your VSS (speed sensor) that needs replacing. Mine does this on and off whilst im driving. Ive purchased a new speed sensor but haven't fitted it as yet but i've heard its a good place to start.
Posted 5th Feb 2014 at 12:32
bennn
Try and make a bit more sense mate.
If you are saying your speedo is dropping to 0 and then kicking back in again, then its most likely the VVS sensor on the gearbox.
If you are saying you'll be driving along and the engine, is misfiring or cutting out, its probably likely to be a sensor of some sort (MAP Sensor, TPS, ICV)
Cherry Red 306 HDI
Posted 5th Feb 2014 at 12:36
doon1988
Check this thread for some info if your issue is what we expect about the speedo dropping:
http://www.306gti6.com/forum/showthread.php?id=145549&page=1
Posted 5th Feb 2014 at 12:47
calumsaddler
Sorry guys was in work. Yes basically ill be driving and the car will run smooth. Then randomly the engine will jolt thats when the mph needle will drop to 0 and it feels like the engine is on tick over but obviously im still moving I can still rev the car but it doesn't accelerate then suddenly just starts working again!! Bit confused haha
sorry about my sentences im a Yorkshire man !!
good to go!!
Posted 5th Feb 2014 at 16:41
calumsaddler
good to go!!
Posted 5th Feb 2014 at 16:42
calumsaddler
good to go!!
pete-gti
So it dropped to 0mph, car revs still but doesn't move?, clutch?
Posted 5th Feb 2014 at 17:14
Sounds like its going into neutral. Not sure if the speedo goes to zero though, never really tried myself.
I have no idea what the issue is, but then I still dont fully understand what you are explaining Laugh
Posted 5th Feb 2014 at 17:16
calumsaddler
No when im driving. say ill be going 40mph it will do it then needle drops to 0 but car still rolls
engine feels like its on tick overi can still rev it but it doesnt do nothing then randomly goes back to normal mate
good to go!!
Posted 5th Feb 2014 at 17:18
pete-gti
If cars still revs , got be clutch ?
Posted 5th Feb 2014 at 17:40
calumsaddler
Ive just had a new 5 plate ceramic paddle clutch in few month ago:/ I was going back to work last night and I noticed I could get up 100+mph fine but when I let off acceleration it feels like its bogging out ive put it down to either vvs sensor like you guys have said or its misfiring from plugs or spark leads but I could be wrong
good to go!!
Posted 10th Feb 2014 at 08:12
Not a clue
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 10th Feb 2014 at 08:58
bennn
I doubt it would be the VSS as this doesn't cause running issues in itself. My money would be on a map sensor, although this wouldn't cause an issue with the speedo.
You could try driving it with the MAP sensor disconnected and see if there is an improvement.
Cherry Red 306 HDI
Posted 10th Feb 2014 at 11:54
calumsaddler
Hmm never thought of that ill give that ago Smile its located behind the battery isnt it ?
good to go!!
Posted 10th Feb 2014 at 12:47
bennn
Its on the inlet manifold mate.
Cherry Red 306 HDI
Posted 10th Feb 2014 at 12:56
woody.
The car won't run with the map sensor disconnected...
Could be a lambda issue, unplug the lambda plug in the engine bay and reset the ecu (battery disconnected for 5-10mins) and give it a run to see if anything's improved
Posted 10th Feb 2014 at 18:05
jimmyhackers
perhaps somethigns gotten inside your engine bay...?
thats far more likely to happen when your bonnets been removed Big grin
Posted 10th Feb 2014 at 18:28
Cjwatson27
Mine done this recently it just dies but don't cut out . I found my gearbox earth had come loose , I've relocated it now and it hasn't done it since
Posted 11th Feb 2014 at 08:02
