Author Subject: Wossner 87mm XU10 pistons and PEC conrods
rallyeash
Hi all,
for sale is a set of 87mm Wossner pistons to fit Gti6. They have been used but only run for 2 hours max. They have cleaned up as new really.
Wossner piston part number is 9181D100 and further specs can be found here.
will create 2044cc running a stock 86mm crank and compression of 12.2 1
http://www.ecosse-peugeot.co.uk/show_product.asp?id=5955
The pistons are attached to PEC G0017 H beam steel conrods and again are as new condition but have been fitted and run shortly.
Complete with ARP2000 rod bolts
specs are as follows
158mm long
20mm small end
53.7mm big end (standard)
further information on the conrods are here
http://www.performanceenginecomponents.com/products/product.asp?id=250326
As you can see from the two links these are £1000 for the set.
£800 delivered
I also have an 87mm honed block which i can include for £100 extra
309 3dr K20 Type R
Posted 5th Feb 2014 at 19:32
Not out of my old engine are they dude ?
Posted 5th Feb 2014 at 19:38
rallyeash
yeah why?
309 3dr K20 Type R
Posted 5th Feb 2014 at 19:41
rallyeash
comes complete with rings too.
309 3dr K20 Type R
Posted 5th Feb 2014 at 19:53
Thought you were sorting the engine ? Shame should of been a weapon motor
Posted 5th Feb 2014 at 21:08
rallyeash
Nah being broken I'm afraid.
Head and cranks sold.
Just block and pistons/rods remaining now
Will split conrods and pistons if there's interest.
309 3dr K20 Type R
Posted 6th Feb 2014 at 18:17
rallyeash
Block is now sold.
309 3dr K20 Type R
Posted 6th Feb 2014 at 19:09
jammapic
If I took the rods, pistons and the block and built it up with a fresh head etc, what else will it need? I read somewhere maybe in a previous post of yours the compression was too high or something? Forgive me if I am wrong...
JP
HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech
306 GTi-6 Track Car - 200+ hp all N/A!
306 DTurbo Track beasty - 209.9hp - RIP
Posted 10th Feb 2014 at 10:24
rallyeash
block is sold I'm afraid.
however take a standard 86mm block to a machining company and they will be able to take it to 87mm no problem.
yes this engine complete had compression issues. ie to high to safely be a circuit engine. Hence why stripping for parts.
You can't just sling an aftermarket engine together, it'll just end in tears. you need build the engine in theory/ on paper unless you just take the pistons/rods to a builder to sort it all out
309 3dr K20 Type R
Posted 10th Feb 2014 at 10:43
rallyeash
Bump.
309 3dr K20 Type R
Posted 16th Feb 2014 at 15:44
rallyeash
Still here!
309 3dr K20 Type R
Posted 18th Jun 2014 at 21:57
jeffers Forum Admin
FOR SALE thread cleaned up, if you're going to have discussion about how or how not to use these, or how good or bad wossner are please do it in the engines section and not in someone's for sale thread.
Thanks
Jeffers
Team Running Engine again!
Team Negative Camber!
Posted 19th Jun 2014 at 23:01
rallyeash
Thumbs up
309 3dr K20 Type R
Posted 20th Jun 2014 at 10:57
so, do you know the compression ratio or not?
Posted 20th Jun 2014 at 12:05
jeffers Forum Admin
Erm here??
Posted 20th Jun 2014 at 13:01
The reason for the engine being oulled apart is excessive compression, as per petes post, theyre nowhere near what is advertised
Posted 20th Jun 2014 at 16:36
dcc
So the compression ratio wasn't known, and as a result the engine was useless? (which in turn lead to the engine being pulled apart)
Any chance of a picture showing the material thickness between the rod bolt and the bearing surface?
205 GTI
Xsara HDI
Posted 20th Jun 2014 at 17:33
pete_rallye
The compression advertised will be using an unskimmed head and an unskimmed block, given my head has been skimmed to the edge of the valves and the block has been skimmed slightly the compression is considerably higher than it normally would be.
I'm now dubious as to whether everything has been calculated correctly with regards to my compression ratio as it seems exceptionally high, so I'm doing it all again tonight, will let you know the results...
There's absolutely f**k all wrong with these pistons, my last engine ran them fine, as do many many others. The quality of them is at least as good as my Omega pistons, if not better.
Lap of the 'ring
Posted 20th Jun 2014 at 18:57
rallyeash
FFS guys. If you ain't interested stay off the thread
309 3dr K20 Type R
Posted 20th Jun 2014 at 19:27
dcc
I am interested though, which is why I was asking such important information?
I am trying to figure what would be needed to make these work well!
205 GTI
Xsara HDI
Posted 20th Jun 2014 at 19:37
jeffers Forum Admin
Come on lads I've cleaned this up once, if ir not interested in buying stay off the thread!!
Posted 20th Jun 2014 at 20:15
rallyeash
Bump.
£700 delivered. Forgot about these!
309 3dr K20 Type R
Posted 23rd Feb 2015 at 11:00
