Author Subject: cams
speedo306
Hi all what the difference between blank cams and reprofile cams Dunno
RJ
Posted 21st Feb 2014 at 22:33
allanallen
Re-profiled are standard cams with re-ground profiles.
Blank cams are completely new (generally) aftermarket cams
Facebook
Posted 21st Feb 2014 at 22:40
speedo306
so its just pulg an play with blank cams
RJ
Posted 21st Feb 2014 at 23:05
eddy_gti6
Depending on spec! Engine mods and management. No none standard cams will run 100% without being set up correctly.
Posted 21st Feb 2014 at 23:19
pete-gti
I'm running a set of re profiled cams, runs fine made no less power :-)
Posted 21st Feb 2014 at 23:34
speedo306
so what aftermarkit cams can i use on standard pistons
RJ
Posted 22nd Feb 2014 at 00:05
pete-gti
Sure I had set of pt80s Kent cams are so mild they run fine, or it was pt81 can't remember going back few years now
Posted 22nd Feb 2014 at 00:08
eddy_gti6
There are a few different options to be honest. There are a few people iirc running Kent PT81s and me and jammapic are running catcam 3107s both sets are as big as you can go on standard pistons but your going to need cam timing and mapped for full performance ect...
Posted 22nd Feb 2014 at 00:23
Cjwatson27
Speaking from first hand experience get someone that knows what there doing to install them and set them up properly , or you to will be making countless threads about your engine not running properly like me !!
Posted 22nd Feb 2014 at 00:28
pete-gti
Yea cjwatson dead right there, cams are major part, need to be done right
Posted 22nd Feb 2014 at 00:31
pete-gti
I tried the pt82 in a spare 6 we had just see if would work, rang like bag of s**t, I do remember pt80s ran perfect and pt81 where OK but didn't run dead right.
Posted 22nd Feb 2014 at 00:33
PT81's are about the max you can go on standard pistons. Yes
And that's only if the head hasn't been skimmed.
Posted 22nd Feb 2014 at 07:43
allanallen
Some real s**t info in here chaps! Pt80s, pt81s will not fit and time in properly in a standard engine, I know people do but there's too much lift at TDC, especially on skimmed heads.
I'm guessing the catcam won't fit either, in fact I can't even see it listed on there site? The 4903106 looks to be the 'biggest' cam you'll get in safely.
I highly recommend you have a read through this topic
http://www.306gti6.com/forum/showthread.php?id=104146
Facebook
Posted 22nd Feb 2014 at 08:06
