Author Subject: Lower rear shock bolt welded in
tony1991
So I'm trying to change my shocks got one side of fine. The other was been a pain so sprayed it with penetrating fluid last night just came back to it hitting it with a sledge not budging so after a little clean around. It looks like it welded in. Can't think why other than a bodge. Any one any ideas of removing it
Posted 4th Mar 2014 at 17:46
Status: Online
hit it harder.
Posted 4th Mar 2014 at 17:47
3rd time lucky
Grind the weld off and replace the bolt?
BLACK RALLYE - Sold
CHERRY RALLYE - new toy
Posted 4th Mar 2014 at 18:01
tony1991
Yer I fort that. But it's the fuel tank side so prob not the best area to have a load of sparks. Should be okay tho. I'm drilling the weld of slowly as we speak think it is working
Posted 4th Mar 2014 at 18:09
aaron6
If you want to use a grinder and are worried, wet a bit towel and cover your concern areas. Tbh it'll be fine. I got all round there with a mig welder and had no issues.
Posted 4th Mar 2014 at 18:13
aaron6
Or cut the bolt down and drill it out if you can fit a drill in.
Posted 4th Mar 2014 at 18:14
scotzman
If you can get to the weld with a hacksaw, you'd be through it in seconds
Posted 4th Mar 2014 at 18:20
I wonder why it's been welded, maybe there's a reason they felt the need to bodge it to stop it coming undone?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 4th Mar 2014 at 21:50
tony1991
Mm may be but I can't see why as those nuts are the ones with the plastic on the end to stop it coming lose ( I can't remember what they are called). I have another beam here if I have problems with it. I'm not too impressed I have found it is missing the bolts that attach anti roll bar to the plates on either end. Which I'm pretty sure they are needed
The bolt I was having issues with I think I few taps with the sledge it should come out now I have got rid of most the weld
Posted 4th Mar 2014 at 21:59
gretsch-drummer
You don't need to remove the bolt though. Just remove the top bolt, compress the damper so you can push it through the mounting arm gap and just pull it off the bolt.....
Ph1 Cossack 6'
Posted 6th Mar 2014 at 22:25
Nylock
Posted 6th Mar 2014 at 22:38
It was me I welded it as I didn't have the right size spanner
Posted 7th Mar 2014 at 17:19
mcvite
LOL
http://s1160.photobucket.com/albums/q486/mcvite/
Posted 7th Mar 2014 at 17:20
bigbadbowen wrote:
Nylock
*Nyloc Thumbs up
  • Posted 7th Mar 2014 at 18:10
    allanallen
    The anti roll bar doesn't have bolts that attach it to the end plates, they're press/knocked on and originally have an Allen head plastic screw fitted to keep the s**t out.
    There's absolutly no reason whatsoever that the bolt should of been welded in! I'm guessing it's around the bolt head? They sit semi captive in the arm and can be very stubborn, sure it's not just a build up of rust and crap?
    Facebook
    allanallen
    dangti6 wrote:
    bigbadbowen wrote:
    Nylock
    *Nyloc Thumbs up
    Plastic holder on'er thingy Thumbs up LOL
    Facebook
    Posted 7th Mar 2014 at 18:12
    pugheaven
    I assumed he was referring to the 13mm bolt that holds the arb end plates to the trailing arm Dunno
    Posted 8th Mar 2014 at 15:01
    oldbrownshoe
    Drill out
    http://www.youtube.com/watch?v=ZhYRMeNdgbU
    http://www.youtube.com/watch?v=rlebZNXxcXU
    French military victories?
    Did you mean French military defeats?
    Posted 8th Mar 2014 at 15:13
    tony1991
    Yes it was the plastic cap to keep the crap out. Still finding my way around the car so sound abit stupid sometimes. It was welded around the head I managed to drill all the weld off but the bolt was so tight I eventually got it out
    Posted 8th Mar 2014 at 19:10
    There is your culprit Tony - he's even admitted it. LOL
    Posted 9th Mar 2014 at 08:04
