| Author | Subject: Wheel studs |
Cjwatson27
The studs look spot on i see you can order individually so might order 1 and try same with the nuts I've been looking at demon tweeks unless there's anywhere else ? Thanks again for the help ________________________________________ Old pugs don't die they just get faster |
devere
Senior User Location: Saxtead Registered: 16 Dec 2008 Posts: 810 Status: Offline |
From a quick Google it looks like the tapered nut people might use is 60 degree taper. Although I stand to be corrected. If that's right tho, that site sells these to match the studs.http://www.rallynuts.com/wheel-studs-and-nuts/ait-m12-x-125-60-taper-open-wheel-nuts.html But if you look on ebay for peugeot 306 taper wheel nuts you will find nuts at a much cheaper price. |
Cjwatson27
I think they need those slim tuner style nuts. I guess the studs are the weak link so any nuts has long has there correct should be ok. Looks like I've got to get the old measuring stick out tomorrow ________________________________________ Old pugs don't die they just get faster |
demondriverdan
Let me know what you use as I'll be using mine with PR 1.2s as well.________________________________________ Rallye Race Car |
Cjwatson27
Will do i take it you need a closed nut to wind these in what sort of thread lock you planing on using ? ________________________________________ Old pugs don't die they just get faster |
devere
I think your probably putting too much emphasis on the stud saying it's a weak link.The studs and nuts hold the wheel against the hub. It's the part of the hub that locates in the centre bore of the wheel that deals with the stresses and forces of the wheel up and down. Hence why when using spacers people use hubcentric. So they don't pass the load on to the stud. As for nuts. On the 1.2's Ive used, that's been with flat faced nuts which are pretty wide with the washer on them also and they fit the wheels fine... I'm not sure I see how you have had issues with needing slim nuts? As for screwing them in I just put 2 wheel nuts on. Clamped them against each other so they locked on the stud and wound them in with those. .. |
Cjwatson27
I get ya sorry I'm quite new to this. Ive got images of all 4 wheels falling off has soon has i leave my drive. I'll have a measure up see what I can use nut wise, I was just going on the fact they have some slim bolts on there at the moment . Cheers ________________________________________ Old pugs don't die they just get faster |
osm2121
Regular Location: Montevideo Registered: 02 Nov 2012 Posts: 229 Status: Offline |
I found out this ones, in France, says it´s 12.9 steel at really good price. Buying 16, you get them at £2.00 each. I really wanted to buy a set, but shipping to Uruguay its just ridiculously high!www.tricompetition.com/fr/pieces-accessoires/goujons-et-ecrous-de-roues/goujon-de-roue-renforce-peugeot-citroen.html |
aaron6
Can you not the buy the studding in a length and cut it down. It is only high tensile steel at the end of the day. As for the nuts, they should be able to be purchased from rally designs for not a lot of money.________________________________________ See the sheer power and might of the lesser known burrowing owl. |
clen666
Post #35
I have a set from tri competition, sold a set to daver6 too. No problems ordering from that site ________________________________________ Team 'unintentional rat look' |
Post #36
aaron6 wrote: Can you not the buy the studding in a length and cut it down. It is only high tensile steel at the end of the day. As for the nuts, they should be able to be purchased from rally designs for not a lot of money. Its not just studding cut down, never seen studding with a shank nor in 12x1.25, nor is it high tensile usually. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Cjwatson27
Post #37
I must have a funny set of pro 1.2 cause I can't fit a 19mm socket in the recess where the wheel nuts are ? ________________________________________ Old pugs don't die they just get faster |
Post #38
is it a cheap ass black impact socket?wheel sockets tend to be slimmer. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Cjwatson27
Post #39
Na it's a normal 1/2 drive one, I've got some 3/4 stuff down the lock up I'll try the 19 from there see if it fits ________________________________________ Old pugs don't die they just get faster |
daver6
Seasoned Pro Location: Durham Registered: 08 Aug 2010 Posts: 2,379 Status: Offline |
Post #40
Cjwatson27 wrote: I must have a funny set of pro 1.2 cause I can't fit a 19mm socket in the recess where the wheel nuts are ? They changed the design slightly so that every 306 in the land wouldn't run 1.2's ________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
Cjwatson27
Post #41
You say that but how often do you see a diablo 306 with silver 1.2 s ________________________________________ Old pugs don't die they just get faster |
daver6
Post #42
Hmm maybe not often....if they're silver..... ![]() How often do you see Compomotive Peugeot Sport wheels... three black and one aerosol silver? :p ________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
daver6
Post #43
Post #44
pretty regularly if you're a rallyist ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
aaron6
Post #45
welshpug! wrote: You can get M12 metric fine high tensile studding. I was just thinking that the price charged for the studs could be halved by using studding which will be more than up to the job that's all. aaron6 wrote: Can you not the buy the studding in a length and cut it down. It is only high tensile steel at the end of the day. As for the nuts, they should be able to be purchased from rally designs for not a lot of money. Its not just studding cut down, never seen studding with a shank nor in 12x1.25, nor is it high tensile usually. ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
Cjwatson27
Post #46
I though about this but the ones from rallynuts are nicely formed and have that shoulder which will help them stay put hopefully ________________________________________ Old pugs don't die they just get faster |
devere
Post #47
Just by cutting down some stud will make for a very half arsed set of studs in my opinion. Having the shoulder to screw them up to is very handy. There wont be any fail safe for the stud going too far through the hub.And the end where you start the nut on, that has a nicely done taper to make it easier to start. For example, the grayston ones don't, and from experience, they can be a massive twat to get on in a hurry. |
aaron6
Post #48
Ah, fair enough. My question answered.________________________________________ See the sheer power and might of the lesser known burrowing owl. |
osm2121
Post #49
clen666 wrote: I have a set from tri competition, sold a set to daver6 too. No problems ordering from that site Would love to buy a set of those, but shipping to Uruguay is about £80!! Only the shipping!! Asked them if they could use a more economic way of shipping, but they wont bother in doing that. |
Cjwatson27
Post #50
£80 seems steep but i bet 16 studs and nuts aint the lightest of things ________________________________________ Old pugs don't die they just get faster |
