Author Subject: Torsion bar removing tool
braymond
I’ve got a pair of 24mm torsion bars which, I suspect still hold a bit of value. However they’re still very much located in whatever it is they locate in (hub?)
Is there anyone around Brighton who has the appropriate tool to pop them out for me??
Rallye-R
Nurburgring article
Posted 24th Mar 2014 at 10:38
Thumbs up
are they stuck in the trailing arm or the crossmember?
Posted 24th Mar 2014 at 10:52
braymond
Trailing arm I would guess. The bars are separate from each other, but each have a lump of car on one end.
Rallye-R
Nurburgring article
Posted 24th Mar 2014 at 10:57
or
Posted 24th Mar 2014 at 11:35
braymond
I did try to tickle them out with option 1, but to no avail.
As for option 2 - I'll check again but I don't think I spotted on in the shed.
Am I wrong in think there is a tool for this then? Is just about accurate deployment of brute force?
Rallye-R
Nurburgring article
Posted 24th Mar 2014 at 11:43
if they are that stuck a puller tool wont do the trick, as its only an M8 thread.
Posted 24th Mar 2014 at 11:51
braymond
I see. Best buy a can of spinach on my way home then..
Rallye-R
Nurburgring article
Posted 24th Mar 2014 at 11:55
I'd just lob them in the boot and find a friendly garage.
Posted 24th Mar 2014 at 12:04
bennn
I used a big socket, a bolt with a nut on it and some big thick washers to wind mine out.
That did the trick for me.
Like this
Socket Method
Cherry Red 306 HDI
Posted 24th Mar 2014 at 12:53
demondriverdan
One of the best things we found was to put the beam on it's end and put a load of WD40 all over it and inside the ARB is it runs down and through. Next day it came apart much easier.
Rallye Race Car
Posted 24th Mar 2014 at 13:18
aaron6
Posted 24th Mar 2014 at 13:19
still relies on the M8 thread, so still limited severely on properly stuck bars Wink
Posted 24th Mar 2014 at 13:55
aaron6
True, but should free most. Smile
Posted 24th Mar 2014 at 15:03
jamiek_uk2000
Well if they are aftermarket bars the beam has been apart so SHOULDN'T be as stuck.
If you break them, I'm not buying them mind lol
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 24th Mar 2014 at 17:14
braymond
Haha Fair!
I'll keep you posted...
Rallye-R
Nurburgring article
Posted 25th Mar 2014 at 08:09
I can get them out for you buddy.
Posted 25th Mar 2014 at 08:20
braymond
Tres bein! I'll give you a buzz when I'm next over your way.
Rallye-R
Nurburgring article
Posted 25th Mar 2014 at 08:34
