Author Subject: Better brakes
tony1991
Not just yet but may be looking soon for slightly better brakes than standard. Is there any brembos that fit under 15'' td pro race 2s
Posted 7th Apr 2014 at 22:06
better to buy good pads.
406 brembos will fit under 1.2's, no idea if they fit under 2's.
Posted 7th Apr 2014 at 22:24
tony1991
Yet I ment 1.2s I was only really asking as there is a set for sale ATM but don't know a great deal about them. Are they the ones that's squeal abit tho?
Posted 7th Apr 2014 at 23:20
yep, also 2 kilos more rotational weight.
Posted 7th Apr 2014 at 23:26
Tarmac terror
I presume the 406 Brembos are a direct fit on the Rallye/6 without any adapters and the need for bigger discs??
TT
Posted 14th Apr 2014 at 11:11
you need a C5/Xantia 288x28mm disc, and the right hoses, but no adapters.
and the right wheels.
Posted 14th Apr 2014 at 11:35
eddy_gti6
You can run the 406 brembos with standard gti6 discs or you can buy the bigger 288 xantia v6 discs. They do fit under 1.2 yes but still isnt much clearance at all. Mine squeal like a b**ch!
Posted 14th Apr 2014 at 11:38
Tarmac terror
Thats good to know.
I'd be using them on spaced 17" Superleggeras so clearance shouldn't be an issue!!
I'll have a look around for some brakes perhaps!!
TT
Posted 14th Apr 2014 at 11:41
dont bother, just buy good pads Thumbs up
Posted 14th Apr 2014 at 11:57
eddy_gti6
Probably the best option. Quite embarrassing when driving through a busy place and having everyone look at you when you brake
Posted 14th Apr 2014 at 12:02
chiefton
Iv got drilled discs with green stuff pads up front and oe mintex on the back . Brakes are excellent!!!
cherry rallye daily (the money pit)
Posted 14th Apr 2014 at 12:11
demondriverdan
If you're not doing much track work, better pads (1144s are good for a daily road car IMO) will suffice. As Chris said, the 406 Brembos are nice but squeal badly if you don't use Tarox G88 discs.
Rallye Race Car
Posted 14th Apr 2014 at 22:51
pugheaven
Dont use the 406 brembos with standard discs, they are not central in the caliper and they are not thick enough
Posted 15th Apr 2014 at 12:43
Yup this is true, the gti-6 discs are to thin for starters their below minimum disc thickness for the 406 coupe when their brand new.
The reason they make so much noise is because of the resonance frequency of the 288mm discs. only way to make sure they never squeal is use G88's as said.
I gave up and just went to 330mm setup instead. sooooooooo much better.
Posted 15th Apr 2014 at 13:46
jamiek_uk2000
330 ftw
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 15th Apr 2014 at 14:20
pugheaven
Iv had the following brakes
406 brembos with xantia v6 discs
willwood 4 pots with standard discs
hi specs with standard discs
tarox 6 pots with 330mm rotors
renault brembos with 310 rotors
renault brembos with 330 rotors
ap racing 4 pots with 315 rotors
if you want to keep with cyclones the willwoods are the best, then the 330 renaults but best by far are the ap's they are bloody awsome and out braked everything on track with no fade what so ever
to be fair my first ever high boost had standard calipers with ds2500 front and rear with brembo discs up front and tarox discs on the rear, they put up with alot of abuse before fade kicked in
Posted 15th Apr 2014 at 14:44
eddy_gti6
Is there any 300mm peugeot discs that will fit the 306 with 407 brembos? Sure I read somewhere someone was running 300mm discs with 406 brembos under 15s. May be mistaken tho
Posted 15th Apr 2014 at 14:53
I think Ash used to do a bracket and a 310mm rotor, not sure they'd have been under a 15" though.
Posted 15th Apr 2014 at 15:25
jorg
i have been thinking about getting some 283x28 belled rotors made up to use with my AP Racing CP5200 calipers. they fit nicely behind a 15" 1.2 and with a 20mm spacer you may get away with cyclones Smile
306 2.1 S16 Tarmac Rally Car
Posted 15th Apr 2014 at 17:14
Tarmac terror
So, seeing as I'm just a noob in the Pug tuning scene, could anyone spoonfeed me with info on brake upgrades?
Seeing as I'm using 17" wheels, rotor size shouldn't be an issue. Can anyone elaborate on what 330mm conversions are out there and what combination of calipers and rotors to use (if they are not from the same vehicle)
TT
Posted 17th Apr 2014 at 10:29
jorg
have a look through the thread below:
http://www.306gti6.com/forum/showthread.php?id=95186
Posted 17th Apr 2014 at 10:31
eddy_gti6
Posted 17th Apr 2014 at 10:32
eddy_gti6
Doh too slow Laugh my ass off
Posted 17th Apr 2014 at 10:33
