Author Subject: Lightened FlyWheel
jameswallace.
Hi looks like im gunna have to take my gear box off soon to sort out some clutch trouble. So while im at it i thought i would like to get a lightened fly wheel.
Anybody have one?? or know of one around? really keen to get one!!
thanks James
Posted 20th Apr 2014 at 08:45
pug_306
I have a couple of good used ones what are they worth?
1992 205 GTi6
205 Turbo 340bhp
Posted 20th Apr 2014 at 09:19
jameswallace.
lightened ones or standard ones to be lightened?
Posted 20th Apr 2014 at 11:33
pug_306
Rich W ones the later type >
1992 205 GTi6
205 Turbo 340bhp
Posted 20th Apr 2014 at 11:34
got any pics of them?
Posted 20th Apr 2014 at 11:41
jameswallace.
Yes please then can i have one of them. as to what they're worth I'm not really sure? Welshpugs probably a good person to ask
Posted 20th Apr 2014 at 13:20
jameswallace.
Ive heard about starter motor issues with these though?
Id be interested in some pictures of them. any wear to the teeth?
Posted 20th Apr 2014 at 13:50
honestly3k
Think it was the earlier type produced flywheels that wouldn't work with the 6 starter motor, also it was the earlier ones that took damage on the teeth
Posted 20th Apr 2014 at 14:11
pug_306
No problem with starting and no damage to teeth. What are they worth ?
Regards
1992 205 GTi6
205 Turbo 340bhp
Posted 20th Apr 2014 at 20:14
dcc
depends how much damage has been done to the surface. These flywheels seem to be very poor quality.
205 GTI
Xsara HDI
Posted 20th Apr 2014 at 19:27
jamiek_uk2000
What are peoples opinions on these then? I've seen a number of people that say they take a hiding and warp pretty easy. I'm going to high boost and track my car so I think I might be better off just getting the standard one lightened and balanced? Or do I just stay standard??
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 20th Apr 2014 at 19:46
pug_306
Ive had one on a lightly tuned engine for over 10000miles on a track car and is one of the best bolt on upgrades ive used, never had any problems with them.
1992 205 GTi6
205 Turbo 340bhp
Posted 20th Apr 2014 at 19:49
jamiek_uk2000
Yeah I have heard loads of people say that they are great, but then I've seen a few heat damaged ones for sale
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 20th Apr 2014 at 19:58
dcc
Those 2 flywheels are Donald Ducked. They need to be skimmed to get a flat surface. They also need to be skimmed properly (entire face) to ensure clamping force is maintained on the clutch.
205 GTI
Xsara HDI
Posted 20th Apr 2014 at 20:01
honestly3k
I used one for 80,000 miles on my 6 before it got rear ended/written off.
Apparently it did have heatspots when it was stripped down but I never had any issues with it, or damage to teeth or anything
But I guess its a case of how many miles they can do before becoming dangerously warped....
Imo not really worth the £260 they cost brand new anyway.......so if you're gonna do it, buying second hand is the best way imo
Posted 20th Apr 2014 at 20:50
pug_306
Ive fitted used ones looking same if not worse with no faults at all. And the 2 that I took off both drove great before removal.
1992 205 GTi6
205 Turbo 340bhp
Posted 20th Apr 2014 at 21:59
Never had any problems fitting used lightened fly wheels ? Got to be worth £130 all day long
Posted 20th Apr 2014 at 22:13
dcc
its a case of fitting something as it is and expecting it to work well, or fixing it and fitting it as it is meant to be. There is no denying the fact that these flywheels suffer terrible from the heat spots. the heat spots them selves are the issue, the material is no longer a flat surface and it will eat into your clutch eventually, it might even start to cause clutch 'judder', the issue is that they will just get worse and worse...
205 GTI
Xsara HDI
Posted 20th Apr 2014 at 22:32
pug_306
They can look like that after 1000miles.
1992 205 GTi6
205 Turbo 340bhp
Posted 20th Apr 2014 at 22:37
dcc
more reason to suggest they aren't up to the job at hand Wink
205 GTI
Xsara HDI
Posted 20th Apr 2014 at 22:44
gman
Mine was a recent generation and the teeth are f**ked. Good upgrade but it seems it's the luck of the draw as to whether you get a crappy one or not
1992 Onyx Black 205 GTI-6
2005 Honda S2000 (Sold)
2002 Audi S3 (Sold)
2005 Clio 182 Trophy (sold)
Posted 20th Apr 2014 at 22:46
rich_w
If anyone has any issues whatsoever with a billet steel lightweight flywheel supplied by me, please don't hesitate to contact me, and I will take your issues up with the manufacturer.
Hot-spots are normal -any grade of steel will suffer discolouration with heat saturation, as brake discs, exhausts etc do.
Hot-spots do not mean the flywheel isn't flat and needs to be skimmed.
These will show hot-spots more so than standard flywheels, due to the reduced thermal mass - I.e. because they are lighter, they will heat up more quickly.
Regards
Contact Details:
07732 822546
Posted 21st Apr 2014 at 09:59
