Author Subject: warning light flashing
calumsaddler
My warning light is flashing like the clappers and the headlights flicker and when the car is on tick over the engine feels like it is going to cut out
can someone help as im confused I think it might be one of the coilpack is on its way out but maybe wrong
thank you Crazy
good to go!!
Posted 21st Apr 2014 at 23:49
pebbles167
If a coil pack has failed it will be running on 3 often, Ie; Horrid. Any idea if it is or not?
Start engine with each coil pack removed in turn.
When the engine doesn't run any different, you've found the culprit Wink
Otherwise it could be, ICV, MAP, probably some other stuff i cant remember, but others will.
2005 Peugeot 206 GTI 180
2008 BMW K1200R
Posted 22nd Apr 2014 at 00:07
calumsaddler
Sweet ill try that after work and not sure I didnt think about it at the time I just took it straight home cause it was like 3 in morning . hadn't had the chance to look at it yet hope it is tho :/
good to go!!
Posted 22nd Apr 2014 at 10:05
RetroPug
A very simple 5-minute thing to try before spending any money might be battery terminals having a poor connection, loose connectors or crap all over them can cause all sorts of issues.
Clean them up and refit them tightly.
Posted 22nd Apr 2014 at 10:14
which warning light?
pebbles167
If its the STOP light, could be the bitron (spelling? ) located in the wheel arch. Vague memories of that being mentioned before.
2008 BMW K1200R
Posted 22nd Apr 2014 at 10:41
Sounds like coil pack? Simple way to check is unplug each injector in turn if one makes no difference to poor idle then that coil is fvcked
Posted 22nd Apr 2014 at 11:11
calumsaddler
Ya its the stop light Ive just been out and the revs are bouncing like mad have to rev it when Im stood still to keep it from dying and when I stopped I lifted the bonnet and both fans where on full blast, the engine was red hot but the temp gauge was reading normal running temp
good to go!!
Posted 22nd Apr 2014 at 21:18
scotzman
Any coolant left in it?
Posted 22nd Apr 2014 at 21:57
calumsaddler
Ya im sure. I check it every long drive, I drive to from leeds to winchester like 2 twice a month unless it leaked out somewhere its one thing after another lol
good to go!!
Posted 23rd Apr 2014 at 10:17
RetroPug
It could just be the ICV. I had a gunked up ICV that caused the stop light, poor idling and stalling.
The headlights may just be the car being close to stalling.
Posted 23rd Apr 2014 at 10:44
calumsaddler
Ill go check now, is it the sensor on top of the butterfly housing (white sensor)?
good to go!!
Posted 23rd Apr 2014 at 15:40
RetroPug
It is next to it in a plastic casing with its own air feed that branches off of the main induction pipe.
http://www.306gti6.com/forum/showthread.php?id=20477
Posted 23rd Apr 2014 at 16:39
calumsaddler
Ive cleaned it seems better but still think it need replacing to stop light is not flashing no more thank god lol cheers guys
good to go!!
Posted 24th Apr 2014 at 08:25
