Author Subject: ROR Fuel pressure regulator
Niall
Evening all.
If you have seen my project thread, you would of seen my car was mapped last month and didn't get too good a result. Only 189bhp ATW. Main reasons was lack of boost (caused by a serious boost leak, was only making 3psi) and failing fuel pump not supplying enough fuel. Ive now fitted a Walbro 255 so fuel pressure is not an issue and boost leak has been dealt with however Steve at track and road suggested at the time fitting a rate of rise fuel pressure regulator before it goes back for re mapping along with the pump and sorting the boost leak. I never asked why i would need one but now wondering, how would it benefit me? Do i really need one or is it just worth going back with the new pump and boost leak fixed?
Posted 27th Apr 2014 at 20:40
It all depends on how much boost you are looking to run, how much power you're looking for and what size injectors you're running.
Posted 27th Apr 2014 at 21:06
Niall
440cc injectors, After about 210-220bhp which should be well within reach on my setup. Once the leak is sealed and new pulley on, should be seeing 7-8psi
Posted 27th Apr 2014 at 21:15
superchargedblack1997gti6
Bang a 4 bar fuel pressure regulator on there that'll give you all the scope you need.
Posted 27th Apr 2014 at 21:18
Niall
Posted 27th Apr 2014 at 21:25
Yep if I'm right I think the correct 4 bar is listed for a vr6 golf
Posted 27th Apr 2014 at 21:37
Based on that information then, I agree with the others. Yes
A 4 BAR FPR will be just the ticket, you won't need any more than that, plus I've never rated those 'rising' ones anyway. Thumbs down
Posted 28th Apr 2014 at 00:00
