Author Subject: Side Moulding GTi & Cabriolet
maxy
Hi everybody,
I have some question about the side moulding of 3 Dr GTI6 & Cabriolet, Does anyone know these item can be directly swap from cabriolet to GTI6 ?
Thank you.
Ph2.5 306GTI-6
Posted 11th May 2014 at 11:49
chiefton
Im sure a cabriolet has slightly longer doors?? Wing one would be fine to swap as long as same phase I wouldvof thought think rear quarter may be ok you should measure them.
cherry rallye daily (the money pit)
Posted 11th May 2014 at 11:56
says same part numbers for the door trims, different ones for the quarters.
Posted 11th May 2014 at 12:31
maxy
Thank you for all replied,
Today, I already measured the actual dimension from actual car and compared the Gti 6 with Cabbie spec. Unfortunately that the cabbie wheelbase is shorter than GTi 6 model for 40 mm. the Doors are same dimension with GTi6 (Some of interior part can be swap with GTI6)
But the length of quarter side panel from the rear end of side door to rear wheelhouse were a little shorter (I'm not sure how much...)
So, Finally I already got all of Phase 3 Moulding from the another Breaking Gti-6. So lucky !
The Moulding is the blue and red in the picture.
Ph2.5 306GTI-6
Posted 13th May 2014 at 16:09
