Author Subject: peugeot sport conrods
morgan205
Here i have some peugeot sport conrods.
The length is 158mm
small end 22mm
big end measured with the bearing in is 44.5.
Dont know what these fit, was told they were ex touring car when they used a 45mm crank
Open to offers around £100ish
Posted 11th May 2014 at 22:43
morgan205
pics
morgan205 has attached the following image:
Posted 11th May 2014 at 22:46
morgan205
pics
Posted 11th May 2014 at 22:47
eddy_gti6
Interested in these if they will fit with the pistons I am getting. Will k ow more in the morning.
Im sure standard big end is 53.7
Posted 11th May 2014 at 23:20
dcc
I can ferry these from mid wales down to south if needed Smile
205 GTI
Xsara HDI
Posted 11th May 2014 at 23:25
jammapic
Be interesting to know what they actually fit.
JP
HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech
306 GTi-6 Track Car - 200+ hp all N/A!
306 DTurbo Track beasty - 209.9hp - RIP
Posted 12th May 2014 at 14:07
pete_rallye
I've got some identical, will fit a 45mm big end steel crank. Can you have a look at the rod bolts and tell me what they say on them? Will be either ARP 2000 or ARP 625+. Let me know what you'll take for them posted to Yorkshire.
Lap of the 'ring
Posted 12th May 2014 at 14:11
JP
A Longman btcc engine, one of the ones with the £1500 small big end forged steel crank, theyre otherwise nearly identical to standard gti6 rods bar being bushed at the small end as per any aftermarket rods and performance engines.
Posted 12th May 2014 at 14:22
jammapic
That's a shame... not shelling out £1500 for a crank!
Posted 12th May 2014 at 14:37
Could just get your crank ground, not sure what the limit is for the XU10 crank, or offset grind a 92mm crank to make a 2.3 Big grin
Posted 12th May 2014 at 14:59
morgan205
Think these would work with a ew10 crank as that's got 45mm big ends but is 88mm stroke so would need some custom pistons maybe?
Posted 12th May 2014 at 17:09
morgan205
SOLD
Posted 12th May 2014 at 20:23
