Author Subject: spring attached to clutch pedal
bas_306gti
Hi,
What's the function of the spring attached to the clutch pedal, inside the car.
I just can't figure it out what it is needed for, I thinks it makes the pedal more heavy than it's supposed to be.
Posted 23rd May 2014 at 20:02
bas_306gti
It is nr. 4 on the picture:
Posted 23rd May 2014 at 20:07
it doesnt keep the pedal up, it pushes it down to keep tension on the self adjusting cable
there was a peugeot tech bulletin to remove them.
Posted 23rd May 2014 at 20:14
bas_306gti
Does this tech bulletin mention the reason it has to be removed ?
As far I can see it only fitted to the XU10JR(S) models.
Posted 23rd May 2014 at 20:26
scotzman
bas_306gti wrote:
Hi,
Man up!!! its supposed to be heavy, you can tell a 306 driver by the girth of his left thighLOL
Posted 23rd May 2014 at 20:47
