Author Subject: peugeot 306 gti 6 rad problem
3gan
nissens rad leaking ever since I removed the bottom hose
tried new rubber O ring
still leaks
pipe also popped out
mechanic said plastic rad connector is broken but I can't see it
can anyone recommend an upgrade
see pic please any ideas if this will work
3gan has attached the following image:
Posted 1st Jun 2014 at 07:26
Replace the rad.
  • Posted 1st Jun 2014 at 08:54
    3gan
    I am gonna replace it soon as I find a good price on Monday
    but I am not convinced its the rad
    and don't wanna waste £150 if its the pipe or even wrong O ring or hose end etc
    Posted 1st Jun 2014 at 09:32
    Have you got underneath and assessed the situation yourself or is the car at the garage and you're going on his word?
    If he's stating that the plastic end is physically broken then either allow him to source a replacement or pass him a Nissens that you supply. If you don't trust him pop in and ask to see it. For the small price a new hose is from Peugeot, I'd get one of them at the same time personally.
  • Posted 1st Jun 2014 at 10:01
    3gan
    it's my mates garage
    I am just not convinced the outlet with the clip attachment is broke and didn't wanna waste £150
    Posted 1st Jun 2014 at 12:54
    RetroPug
    I'd be concerned about using a silicone reducer clamped to another hose for a pressurised coolant pipe myself. Might fit up all fine at first glance and under short test drives then pop off once up to temperature.
    By all means check that it really is broken but for peace of mind i wouldn't want to have hoses clamped to other hoses.
    Posted 1st Jun 2014 at 13:17
    3gan
    Yes I agree just cant believe how pants this fitting really is
    Posted 1st Jun 2014 at 15:39
    Rich E Forum Admin
    In my experience this is always the pipe not being clipped into the radiator correctly. It can be a bit fiddly to get it clipped in correctly but if correctly fitted I've never found to pop off, and a new seal always cures leaking issues.
    I'd remove the radiator and hose and fit them up off the car to confirm what the actual problem is. If the connector on the radiator is damaged then I'd replace it rather than try to botch something together.
    The thermostat cap outlet joint is exactly the same as the later lower radiator connector and that never pops off.
    Posted 1st Jun 2014 at 15:47
    cully
    if the wire clip has been removed from the rad neck, check it has been fitted back in the correct place as you can get it wrong letting the pipe fitting not clip in
    Posted 1st Jun 2014 at 18:47
    3gan
    I believe this was my fault after fitting the O ring and the pipe coming off
    but the pipe drops in so easy and the clip goes on too easy it is too loose a fitting
    maybe the rad pipe neck is knackered
    Posted 1st Jun 2014 at 18:55
    If that is the case, it sounds like the rad neck is cracked and opening up when you put the pipe in and that's why it slides in too easily and doesn't feel secure.
    New rad time. Yes
    Posted 1st Jun 2014 at 19:37
    3gan
    new rad and new pipe I think mate
    Posted 1st Jun 2014 at 20:02
