Author Subject: Plug leads
RallyeP6
Hi All, will be changing my standard ECU to a DTA E48, so need to use a DIS ignition coil not the coil on plug type. Does anyone know which plug leads i can use with the XU10J4 head so that it seals the plug bores properly.
Also did the phase 1 S16 have DIS ignition or coil on plug or coil pack type.
Thanks.
Posted 7th Jun 2014 at 12:33
With my DTA S60 I use leads from a 16v Corsa.
  • Posted 7th Jun 2014 at 14:46
    RallyeP6
    Brilliant Dan, thanks for that, can start searching for that then.
    Posted 7th Jun 2014 at 17:08
