Author Subject: overfuelling
mjt4130
My 6 is overfuelling and failed it's MOT. Have replaced the Lambda sensor and still just as bad. Is it worth trying an ECU reset before I do anymore sensor testing? Its got a daft sports cat if that makes any difference?
Posted 10th Jul 2014 at 18:31
mjt4130
Fast idle test: engine speed 2500-3000 co- 6.7% hc 292 lambda 0.847 No
Posted 10th Jul 2014 at 18:47
Failed its mot on what ? Emissions ? If so then yes the cat will be the problem
mjt4130
Yes, failed on emissions.
Posted 10th Jul 2014 at 18:53
Sports cat will be the problem then
Posted 10th Jul 2014 at 19:14
not likely, the CO is massively high, the cat wont bring it down that far, check the green ecu temp sender.
Posted 10th Jul 2014 at 19:21
Could be a combination of the more than one thing but I bet if you got a decent original cat emissions would come right down Thumbs up
Posted 10th Jul 2014 at 19:30
mjt4130
The green sensor is next on my list as the cat is welded to the rest of the system- Its a Cobra sport made in situ type thing.
Posted 10th Jul 2014 at 19:47
mjt4130
New ECT sensor and still over fuelling so trying a cat next.
Posted 11th Jul 2014 at 19:12
