Author Subject: mocal oil cooler hose
daver6
Hi, just after some info from those with a cooler fitted.
What length are the hoses? What connectors are at each end? Straight or 90*
Wishbone Polybushes available
Posted 24th Jul 2014 at 07:42
depends where you put it.
Posted 24th Jul 2014 at 08:26
allanallen
depends what cooler you're using and where you fit it. Mocal is either 1/2 or 5/8 bsp, setrab and some others use metric fittings.
you need to fit your cooler, plan your pipe route and then measure the lengths. Rally designs is a decent/cheap source for the push fit mocal pipe and fittings.
Facebook
Posted 24th Jul 2014 at 08:28
jeffers Forum Admin
My 16 row Mocal cooler has -10 Jic fittings and 5/8 hose to the adapter plate, bought all the gear from Merlin Motorsport, Think automotive also sell everything you need. Personally i've used push fit connections and bought the hose in metre lengths and just trim to size, they've worked fine but you can also buy crimp on connections, push fits worked fine for me though. Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 24th Jul 2014 at 11:04
daver6
Ah right I'll mock it up and work it out. Just thought the spare Rallye rad fan space to mount it.
I'd thought there'd be some idea of length due to being able to buy a mocal kit. I've got their sandwich plate and 13row cooler with 1/2 bsp
Posted 24th Jul 2014 at 22:06
