displaying posts 26 to 35 of 35
Pages (2): 1 [2]
Author Subject: Harness bolt point
demondriverdan wrote:
] and weld it in with the nut inside the hole
eek!!
youre meant to put them on the other way, theyre not meant to eork that way round!
Posted 6th Aug 2014 at 20:14
What I did - which I assumed was correct:
Drilled a hole big enough for the eye bolt to go through and put the square plate underneath the floor with the nut facing down to the ground. The eye/head of the bolt effectively uses the floorpan as a washer.
  • Posted 6th Aug 2014 at 20:27
    Thumbs up
    Posted 6th Aug 2014 at 20:49
    jamiek_uk2000
    Yeah that's the plan. Just using gripfil to hold it to the car until I can get back onto and put the bolt it. That either means I have no friends or I am preparing incase I have to remove the harness a few times
    Looking for:
    VTS P1 Rack
    PR1.2 16"
    Posted 6th Aug 2014 at 21:01
    demondriverdan
    I need to check what I've done but I'm fairly certain I described it right. When we drilled a hole through there was another layer underneath so I'm not sure how you welded the plate in from underneath?
    Rallye Race Car
    Posted 6th Aug 2014 at 21:02
    Chr1sch
    Daft question (possibly) can you run harnesses if the buckets are on sliders?!
    Posted 14th Aug 2014 at 08:20
    yep, its not ideal, you'll just hsve to adjust them every time you move the seat
    Posted 14th Aug 2014 at 08:30
    Chr1sch
    Thought as much, but useful to know. So is the overall conclusion that these lugs need to be welded into the rear floor to mount harnesses?
    Seems logical but one heck of a faff, i recently removed my rear seats and there are 2 very large what appear to be brass (over an inch tall) big lugs coming through the floor - any idea what the heck they are?!
    Posted 14th Aug 2014 at 09:35
    lugs for the seat base, yellow zinc plated steel
    Posted 14th Aug 2014 at 11:51
    Chr1sch
    Post #35
    balls, not harness mounts then lol
    Posted 14th Aug 2014 at 17:16
    Pages (2): 1 [2]
