Author Subject: pressure plate
speedo306
Hi guys just put in a new clucth plate and new clucth cable , i used back the old pressure plate but now i am not getting any gear in when i start the car but when car is off the gears goes in could it be the pressure plate Dunno
RJ
Posted 7th Aug 2014 at 16:27
allanallen
Have you put the plate in the right way around?
Facebook
Posted 7th Aug 2014 at 15:50
speedo306
yes and i also jack up the car put it in 1st gear and then started it then put my foot right down on the clucth Pedal wheel still moving do a pressure plate go bad
RJ
Posted 7th Aug 2014 at 16:26
friction plate in wrong way round or broken clutch cable, or you did not get the clutch fork fingers behind the bearing.
speedo306
yes did get clutch fork fingers behind the bearing and i put in a new clutch cable
RJ
Posted 7th Aug 2014 at 16:32
speedo306
anyone
RJ
Posted 7th Aug 2014 at 20:57
Niall
New cable yeah? Try stamping on the clutch a few times. May just need to adjust a bit
Posted 7th Aug 2014 at 20:58
friction plate on wrong probably
Posted 7th Aug 2014 at 21:00
speedo306
just put it down again and the friction plate right place
RJ
Posted 8th Aug 2014 at 00:39
